 Post subject: WD60EZRZ, weak head. Blizzard vs. Rossmann?
PostPosted: October 24th, 2026, 22:24
WD Blue 6 TB (WD60EZRZ), slowly failing. Read errors are getting worse with each read, likely a weak head. Partial clone done, but critical files are missing. Considering Blizzard Data Recovery or Rossmann Group. Any experience with either for head swaps?
 Post subject: Re: WD60EZRZ, weak head. Blizzard vs. Rossmann?
PostPosted: October 25th, 2026, 5:33
Both will be fine - If it's still reading it may not even need replacing. Rossmann has a longer turn around time if I recall , especially at the moment. Blizzard is also likely to be cheaper if that's a concern.
PostPosted: October 25th, 2026, 21:10
Thank you for a quick reply. They do have cost and processing time listed. What I am trying to get is the sense of lab capability if mechanical issues need to be mitigated. Could not find much info online.
PostPosted: October 26th, 2026, 8:38
I suppose it's a such a common operation, it's a bit like asking which garage does the best tire change. It's kind of a nonsense question.
PostPosted: October 26th, 2026, 19:45
I found WD blue hard disks to be rather flakey at best. Some Seagate barracuda disks are equally dismal
I turned to enterprise class disks which have lasted
PostPosted: October 26th, 2026, 23:55
Which enterprise disks?
what is the definition of "flakey"?
How long did your enterprise disks last?
did you run Seatools on them? as it would have fixed them
PostPosted: Yesterday, 9:07
Sure. It is so common, that my cat does 2 head replacements before breakfast. Thank you for valuable information. It really helped.
Users browsing this forum: Google [Bot] and 174 guests
