 Post subject: ST3808110AS
PostPosted: Yesterday, 11:08
Online
ST3808110AS
Need ldr (7200.9 Tonka2)
3.ADJ
Thanks in advance.
 Post subject: Re: ST3808110AS
PostPosted: Yesterday, 12:10
Online
Found it on hddsurgery fw database.
But the problem still, and I get ATA ovl address failure.
Any suggestions?
Thanks in advance
PostPosted: Yesterday, 12:26
Online
4096k x 16 SDRAM
TONKA2 - 1_Disk M-31 03-22-06 10:53
Head Mask FFFF - Switch to full int.
Spin Ready
(P)SATA Reset
DiskAccess ReadSector EC=43 at ffffffff.00.0002
12FFLUSH-1 Fail
CE Log ErrCode=0 LBA=0 Type=aDiskAccess ReadSector EC=43 at ffffffff.00.0059
Failed sys sect. write! Nwt Er 33 RdWr 15d5f.00.0007
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
Failed sys sect. write! Nwt Er 00 RdWr 15d5f.00.0007
Initializing SMART SectorsFailed sys sect. write! Nwt Er 33 RdWr 15d5f.00.0007
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
Failed sys sect. write! Nwt Er 00 RdWr 15d5f.00.0002
Unable To Load Overlay 01|000A
PostPosted: Yesterday, 12:29
Online
I can read user sectors via terminal, but it's very slow.
PostPosted: Yesterday, 16:05
Is anything readable from the SA? Either the heads (surface) are dead, or someone formatted it with an m0... format. :)
Writing to the SA can be forced (1>F), but that might worsen the user data situation.
PostPosted: Today, 9:20
Online
Problem solved after uploading ovl to memory and cloning with 3mb/s via mrt utility.
Thanks.
Users browsing this forum: skinbob, unknown and 192 guests
