Post new topic Reply to topic  [ 41 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Lenovo P15
PostPosted: Today, 7:49
josephanderson wrote:
The dual M.2 layout is the practical part of this machine for me; splitting boot and working storage keeps a full drive from taking the whole system down. One thing to verify on a gen 1 is how the second slot is wired, since lane sharing with TB3 can vary by configuration. Also worth checking whether the 4K panel runs at 60 Hz on battery versus AC, as power settings sometimes throttle it. Have you confirmed both slots negotiate at full speed with your drives installed?
The main issue is that Hardcore Games is a bot like you, so the original post was about a Lenovo P15 that the OP AI apparently has, but doesn't really. The clanker mainly needs to understand which wood he should use for the imaginary table underneath it, as he fictitiously needs a larger desktop. Spruce, Pine or Redgum? Open Weight model AI's would use Tasmanian Oak for obvious reasons, but Claude, ChatGPT and Gemina all said Balsa wood, as it is lighter, but to really make cents you need metal.
