 Post subject: why does my drive lost capacity?
PostPosted: August 3rd, 2005, 22:11
i have a IBM 60G harddisk,but os and bios recognize only 40G.why?
what can i do?
 Post subject:
PostPosted: August 4th, 2005, 9:30
Here you go:
http://mhddsoftware.com/forum/viewtopic.php?t=4261
 Post subject:
PostPosted: August 4th, 2005, 23:39
thank you very much!
 Post subject:
PostPosted: August 7th, 2005, 5:57
i'm sorry .but there isn't some answers to my quenstion
 Post subject:
PostPosted: August 7th, 2005, 12:57
Did you try nhpa and config?
 Post subject:
PostPosted: August 9th, 2005, 1:08
yes,i have run nhpa and rhpa, it also shows 33GB.
 Post subject:
PostPosted: August 9th, 2005, 9:14
Then you have jumpers set wrong. The drive has a sticker with all jumper settings. After you return jumpers on their places, you'll probably need to do nhpa/config again.
 Post subject:
PostPosted: August 10th, 2005, 0:46
thank you for your help ,i have do it as you say,but failed.
 Post subject:
PostPosted: August 10th, 2005, 9:45
Ok, what are the jumpers now?
They should look this way:
J::J
 Post subject:
PostPosted: August 11th, 2005, 0:33
yesterday morning ,i fixed the harddisk as you say ,but failed.then yesterday afternoon, fixed it using same order,but successed.why ?
today ,when i'm copying data from this drive ,the electricity cuted suddently,then this drive' capacity still is 33G.and when i try to fix it as yersterday ,but failed.why?
thank you.
 Post subject:
PostPosted: August 11th, 2005, 9:56
Can you please do the following:
2. Run MHDD
3. Detect the drive (Press F2)
5. Press F10. You will have screenshot saved into a file.
7. Post the screenshot here.
Users browsing this forum: No registered users and 274 guests
