 Post subject: can we open the bad drive to retrieve the data ??
PostPosted: August 12th, 2005, 0:47
I have a defective maxtor drive (why always be maxtor ??? :( )
somebody tell me that I can retrieve the data with opening the drive in clean air and than retrieve the data ???
I already read some article about it. many says that only very expert can do it, and it also need some special tools.
but I'm still not sure, can anyone tell me is there any way to retrieve the data ?
btw. the drive already dead (motor not spindle anymore !! ) :(
 Post subject:
PostPosted: August 12th, 2005, 1:12
hi,
It is not a good idea to start HDA repairing with a HDD that contains valuable data - IMHO.
One can easily cause irreversible damage to the drive, so I suggest experiencing with spare hdds.
BTW why do you think it is neccessary to open it?
 Post subject: I know
PostPosted: August 12th, 2005, 16:29
But its using a MFM Microscope Force Magnetic very expensive and very difficult to use, and learning , readding directly the pattern in platters , and decoding with PRML channel . like i said very difficult ..... does any one know another way?
 Post subject:
PostPosted: August 12th, 2005, 17:34
no one uses that :) maybe ontrack...
 Post subject:
PostPosted: August 12th, 2005, 20:33
Ontrack does not use that ;-)
 Post subject:
PostPosted: August 13th, 2005, 3:09
 Post subject:
PostPosted: August 13th, 2005, 13:18
So beside open the harddrive, any suggestion to retrieve the data when the motor already dead ?
 Post subject:
PostPosted: August 13th, 2005, 15:32
hi,
it depends on what the problem is with the motor.
Users browsing this forum: No registered users and 211 guests
