 Post subject: help needed.
PostPosted: August 21st, 2005, 3:06
I have maxtor D540X-5X, 40GB. it's detected in BIOS. when I try using MHDD to scan for bad sector. it came around 20 UNC and have some green and red block. then I try to use "erase". it working good. but when it finished, it start to knocking sound hard but just for a while. then I try to use "scan". everything become "abort" ("!" sign) and start to knocking head again, this time very hard and long. Why this happen ??? it there something wrong i'm doing ?
since then my harddisk cannot be detected anymore, either in BIOS and in MHDD ???
I don't know what wrong ?? can anybody help me ??? Is there any chance MHDD has broke my hdd ??? now i cannot use my harddisk anymore.
p.s. I also try to using pc3k to repair it, but failed (not detected also)
thanks..
 Post subject:
PostPosted: August 22nd, 2005, 9:39
hi tony
i am not an expert in maxtor, but it looks from others posts
that this drives are fu**ing bad.... they have a lot of problem with firmware and mechanics
dont think mhdd caused this problem i have used mhdd
on many drives and it never caused any problem.
sometimes things happen to hdds and they are a mystery... :evil:
 Post subject:
PostPosted: August 22nd, 2005, 23:17
i also have this drive.. The problem is same....
if can be detected by BIOS it just running well..... but If can not..it will knocking.. I think maybe some problem with head......
:( I have try to repair before....... but since this type is Fu**ing bad... I think I dont want waste a lot time for this drive........
 Post subject:
PostPosted: August 23rd, 2005, 5:38
maybe the glist overflow causes the firmware disfunctinon. it should be use pc3k or hrt to repairing.
 Post subject:
PostPosted: August 24th, 2005, 12:18
thanks alot for the suggestion.
but in some level i still believe mhdd is a great software for repairing hdd. cause i already fix some harddisk using mhdd and all of it running well now.
I never use HRT ?? can yuanfang tell me to HRT function...
hehehe..
thanks
Users browsing this forum: Pandemicc, Roots Data Recovery and 371 guests
