 Post subject: Correct Modal / Wrong Serial
PostPosted: August 24th, 2005, 1:24
Hi all,
again a samsung SV2001H. The drive head was damaged. I swapped the heads from another same model drive.
Now the drive is getting detect in the bios.
the model number is correct.
the geometry is correct.
But ........ the serial number is wrong. Its something like $$2041415.
No utility is able to read sectors from the drive.
regards
 Post subject:
PostPosted: August 24th, 2005, 1:55
hi
please post the log from mhdd here ,
the drive status is important , buisy ready.. etc
i dont have much experience with replacing heads but seems
there are firmware problems also , if the serial number isnt shown
correctly the firmware is bad.
regards
A>S
 Post subject: SMART
PostPosted: August 26th, 2005, 7:27
here is the SMART report from MHDD
[PRE]HDD: SAMSUNG SV1022D; FW: MK200-49; SN: MK200-49
Name Val Worst Raw
Att # 1 : Read error rate : 100 100 8
Att # 4 : Number of spin-up times : 99 99 1986
Att # 5 : Reallocated sectors count : 253 253 0
Att # 7 : Seek error rate : 253 253 0
Att # 8 : Seek time performance : 253 253 0
Att # 9 : Power-on time : 100 100 76182
Att # 12 : Start/stop count : 99 99 1985
Att # 197 : Current pending sectors : 253 253 0
Att # 198 : Offline scan UNC sectors : 253 253 0
Att # 199 : Ultra ATA CRC Error Rate : 200 200 0
Att # 200 : Write error rate : 100 100 0
Att # 201 : Unknown : 100 100 0
[/PRE]
 Post subject: Re: SMART
PostPosted: August 26th, 2005, 7:56
The bug... http://mhddsoftware.com/forum/viewtopic.php?t=4731
+ Fixed displaying firmware version instead of serial number in SMART ATT
Users browsing this forum: No registered users and 331 guests
cron
