 Post subject: Toshiba MK1214GAP Problem
PostPosted: March 21st, 2006, 7:11
HI all Friends,
I have a Toshiba MK1214GAP..LBA 23,579,136 sectors...12.07 gb
Mhdd29 shows:
TOSHIBA MK6014MAP 12416/15/63
SN:30P103121T FW:N2.10 A LBAs:11733120
Support: LBA HPA DMA (UDMA4,MWDMA2)
SMART: Enabled
Security: high, OFF. Size = 5729Mb
Device Reset... OK
Setting Drive Parameters... OK
Recalibrate... OK
I want to recover data from it.
Can anyone help me ? :roll:
I will be very thankfull to him.
 Post subject:
PostPosted: March 23rd, 2006, 7:41
Is there is any hope of drive repairing ??only repairing..
 Post subject:
PostPosted: March 24th, 2006, 6:37
MHDD then NHPA
 Post subject:
PostPosted: March 24th, 2006, 7:10
Mhdd29 shows:
Mistakes are not present?
 Post subject:
PostPosted: March 24th, 2006, 8:43
Sounds like the label of the 12Gb GAP has been placed on the 6GB MAP.
Has the drive been opened or cover plate removed ?
Does the 6GB drive scan in MHDD ?
 Post subject:
PostPosted: March 24th, 2006, 9:25
Thanks all for reply.. :)
I can not read or verify thru mhdd from starting sectors of drive...(from 0 to 1000(approx))show xx(uncorrectable ecc) .
then i check from 1000000 sec ,it is verifies thru mhdd ..but very slow lots of green and also after some sectors clicking sounds occurs .. :( and do not verify.
BGman
MHDD then NHPA
Thanks friend for your suggestion,but problem is something different.I don,t know how, but the labels model no. is different from hdds model no.
MonRepos
friend this is the first mistake:
label shows:Toshiba MK1214GAP..LBA 23,579,136 sectors...12.07 gb
Mhdd29 shows:TOSHIBA MK6014MAP 12416/15/63 LBAs:11733120
then hdd do not running fine, as i write above..
coffeebean
Friend, no drive is not opened.it is slead. and also confermed that when drive run ..run as MK1214GAP.it is not MK6014...
Is there any idea ...what is wrong with drive..? :roll:
Thanks Alot
 Post subject:
PostPosted: March 24th, 2006, 9:44
Online
the drive's PCB has been replaced from a 6014GAP.
Find its original board if possible!
regards,
 Post subject:
PostPosted: March 24th, 2006, 10:13
Right. Only original.
 Post subject:
PostPosted: March 24th, 2006, 16:15
I would suggest that if pcb is wrong not one sector would read.
Friend, does pcb have a label describing fw version ?
 Post subject:
PostPosted: March 25th, 2006, 4:08
Online
This is not true in this way.
Once I had to replace the PCB on a 6014MAP since the controller was burnt out by misaligned connecting.
I replaced the board from a similar drive, it was reading all the stuff, but in the image there were shifts I had to repair to access data correctly.
BTW the model number is stored in ROM within the processor, consequently the board IS from a 6014MAP.
regards,
 Post subject:
PostPosted: March 25th, 2006, 9:04
hi,
Thanks All for your help... :)
I could not find out the solution for that drive ,because i do not have drive now (customer took away today :oops: )..
But i am happy because i find many friends here. :)
Thank for your interest in this topic.I know we can solve that problem.but...
(as i write above)
Friends,
here i want to discuss another thing. Is this is possible to repair toshiba drive without pc3000pci (Thru terminal),if it is a problem of f/w or as some friends say pcb rom problem. :roll:
I tried terminal command written in pc3000pci manual ..don,t find them good enough...What you all thinks about it...?
Thanks Alot for All Friends
Users browsing this forum: No registered users and 297 guests
