 Post subject: Maxtor YAR41BWO Help
PostPosted: August 1st, 2006, 15:13
What are the chances of swapping the platter (single) to a working unit of same model/code? Is head alignment an issue? PCB tested ok on other drive.
Thank you
Maxtor DiamondMax Plus 9 80GB ATA
Code: YAR41BWO K,F,G,A
6y080l04220p1
made in 2004
 Post subject:
PostPosted: August 1st, 2006, 17:09
After testing with some spare drive, I found that when removing the platter, the fit is not exact. There seems to bee a fraction of a mm of sideways play. This can't be good. I suspect changing the head stack (2 heads) would be safer, since by removing the platter, it would be impossible to have it 'centered' the same way as it was before.
Or is there a way around this. Whould the minor off center be still readable?
I wish there was more info on this subject on the net, it's dissapoiting how unavailbale this kind of info is. Damn recovery labs, keeping all this for themselves!
 Post subject:
PostPosted: August 1st, 2006, 22:59
Yes, that is not good. Changing heads would be a wiser idea...
 Post subject: Theroretically
PostPosted: August 2nd, 2006, 7:16
Would it be feasable to change the one platter and have drive calibrate, or is it impossible?
 Post subject:
PostPosted: August 3rd, 2006, 12:13
i have changed the whole media to another hdd of the same model and it worked fi9 . maybe u should try changing those heads the hdd may work ok
 Post subject:
PostPosted: August 3rd, 2006, 15:19
Banned User
yes u should try toooo....it is a good idea.
 Post subject:
PostPosted: August 4th, 2006, 11:25
I was asking specifically if one could successfullt change the platter, or not.
 Post subject:
PostPosted: August 5th, 2006, 7:42
it is possible to center one platter, as it is needed in DM+ 8 drives having head related failures. However if it is possible to change only the head assembly, U should do that. I mean if the motor is not seized and the windings are workable (not shorted or broken).
Up till now I haven't succeeded changing more than one platters.
Anyway U may need head alignment if the original head assembly is damaged.
regards,
 Post subject:
PostPosted: August 5th, 2006, 10:42
thank you for info.
Would you center the platter using a spacer such as a piece of paper all around the spindle to remove the gap?
Does the Maxtor factory center the platter or just leaves it as is, off-center and formats the drive?
How would one perform ahead alignment?
Thanks again
 Post subject:
PostPosted: August 11th, 2006, 7:43
Tried centering a platter on a spare drive using scotch tape around the spindle, and the tape was a bit too thick, the platter was too hard to push down on the spindle.
What do you guys use?
Users browsing this forum: No registered users and 146 guests
