 Post subject: seagate momentus 4200 st93015A pcb swap failed
PostPosted: August 21st, 2006, 0:05
I tried to swap logic boards of two identical seagate 30gb HDD, after the swap the hdd does not get detected.
Find below the config. of both the hdd
Hdd with fried logic board :
Model : ST93015A
Pn : 9Y1412-331
HDA PN NO : 100302056
date:04386
HP: 356013-002
fw: 4.07
cfg: nhm-04
ct: 27B39006CQ13LJ
Working HDD
Model : ST93015A
Pn : 9Y1412-331
date:04353
HP: 356013-002
fw: 4.07
cfg: nhm-03
ct: 27B39006CPY4AR
As far as i can see the cfg no and the batch date are different. Is this the reason as why my logic board swap is not working.
Thanks in advance.
 Post subject: Why
PostPosted: August 21st, 2006, 13:02
Why did u swap the PCB? What was the problem in hard disk.
DF :croco:
 Post subject: Re: Why
PostPosted: August 21st, 2006, 23:41
DF :croco:
My HDD was making clicking sound and wen i opened the board i found broken chips.
 Post subject:
PostPosted: August 22nd, 2006, 1:57
Dear ragga_van
Swaping pcb is good option but it may not work always. Even after changing pcb disk is having same problem it could be
1) head problem.
2) firmware damage.
if data is importent than it is good to take it to a recovery lab.
DF
 Post subject:
PostPosted: August 22nd, 2006, 10:35
darkfroce1 wrote:
Dear ragga_van
1) head problem.
2) firmware damage.
DF
After changing the pcb, my hdd is not getting recognized, how ever i dont hear any click sounds
 Post subject:
PostPosted: August 22nd, 2006, 13:16
Could be bearing/ head jam
:roll:
 Post subject:
PostPosted: August 27th, 2006, 6:38
is the power there in the replace of the new hdd pcb .
Users browsing this forum: No registered users and 441 guests
