 Post subject: Maxtor Diamond 9 Series
PostPosted: September 16th, 2006, 18:04
hi
my harddrive has recently been having problems :(
one day, after turning on my computer i was unable to move certain files around, message was "data corrupt."
then i removed the harddrive to try it in anothing comuter, and it said the same thing.
now, i put the harddrive back into my computer, and i cannot see it. The hardware manager can see it, but no drive icon shows up. i tried a couple recovery tools, but they just hung then quit.
it sounds like its not turning
any ideas on problem and fixes?
all help appreciated!
thanks in advance
 Post subject:
PostPosted: September 17th, 2006, 5:08
i think u hav bad sectors try repair with victoria or mhdd using advance remap option then use prosoft media tools for recovery of data .
 Post subject:
PostPosted: September 17th, 2006, 20:14
thank you for your reply! i shall give it a shot and report, thanks again
 Post subject:
PostPosted: September 18th, 2006, 2:36
if u need the data, U should not run victoria!
just create an image of the bad drive and try some logical recovery SW on the image.
regards,
 Post subject:
PostPosted: September 20th, 2006, 3:51
i think his hard drive has bad sectors so i have given him the solution to repair then recover .
 Post subject:
PostPosted: September 20th, 2006, 8:27
Is not a good idea!!!
DataRecovery.bg
 Post subject:
PostPosted: September 20th, 2006, 18:44
hi
well i already tried creating an image of the disk, from DOS before windows load.. but the program just halted and wouldn't get past the loading screen :(
is there another way to make an image of the drive?
 Post subject:
PostPosted: September 21st, 2006, 12:39
what prog did U use?
 Post subject:
PostPosted: September 22nd, 2006, 7:15
hi
it was Drive Clone
the one that just stalled all the time :/
 Post subject:
PostPosted: September 22nd, 2006, 9:36
try copyr or media tools.
logical recovery SW will fail on the bad drive very probably.
regards,
 Post subject:
PostPosted: September 24th, 2006, 21:02
hi again
no luck :(
copyr won't boot up
and media tools can't read the drive, neither can DivX (if thats correct, i forget)
bios reads the drive just fine, hardware manager as well; but nothing else :-/
any more ideas? do i need a new board?
 Post subject:
PostPosted: September 25th, 2006, 1:43
How do u run the media tools but up in DOS then try .
 Post subject:
PostPosted: September 29th, 2006, 1:38
You need PC3000 for this case, may be some module on it is damage. If can not repair, you need Data Extractor for recover data.
Users browsing this forum: mima85 and 91 guests
