 Post subject: Problems checking IBM xSeries 335 w/ Deskstar IDE Drive
PostPosted: November 13th, 2006, 15:14
I've had reports via smartmontools of SMART errors on these IBM xSeries 335 w/ Deskstar IDE Drive. When I run MHDD all the sectors are green (150ms) I've never seen this before. Any ideas why?
 Post subject:
PostPosted: November 13th, 2006, 15:25
could you post SMART here ?
 Post subject: Log
PostPosted: November 13th, 2006, 18:43
[PRE]HDD: IC35L090AVV207-0; FW: V23OA66A; SN: VNVC30G3CVSLHT
            Name                        Val Worst Raw
Att #   1 : Read error rate           : 100  100  65536
Att #   2 : Throughput performance    : 126  126  374
Att #   3 : Spin up time              : 104  104  17236233
Att #   4 : Number of spin-up times   : 100  100  58
Att #   5 : Reallocated sectors count : 100  100  72
Att #   7 : Seek error rate           : 100  100  0
Att #   8 : Seek time performance     : 123  123  37
Att #   9 : Power-on time             :  96   96  28838
Att #  10 : Spin-up retries           : 100  100  0
Att #  12 : Start/stop count          : 100  100  58
Att # 192 : Power-off retract count   : 100  100  114
Att # 193 : Load/unload cycle count   : 100  100  114
Att # 194 : HDA Temperature           : 183  183  30
Att # 196 : Reallocate event count    : 100  100  77
Att # 197 : Current pending sectors   : 100  100  0
Att # 198 : Offline scan UNC sectors  : 100  100  0
Att # 199 : Ultra ATA CRC Error Rate  : 200  200  0
[/PRE]
 Post subject:
PostPosted: November 14th, 2006, 13:14
I was able to run MHDD on a third x335 and it did not have all green sectors. I'll post the logs later today.
 Post subject:
PostPosted: November 14th, 2006, 14:47
A disk has 72 remapped bad blocks and 5 candidates to bad blocks
The disk is dieing
 Post subject:
PostPosted: November 14th, 2006, 19:10
I agree with Doomer,
It looks like your disk is on it's way out. I would backup the drive if it contains any important data and then possible try a LL Format.
If it's soft sector problems this may set things straight, but If it's a physical problem you may want to just toss the drives.
 Post subject:
PostPosted: November 15th, 2006, 2:13
These IBM deskstar drives are prone to head failure (hence the nickname deathstar!) and also prone to "Phantom" bad sectors caused by bad connection between PCB and HDA.
I agree with quasimodo, you should back up your data and toss the drive :)
 Post subject:
PostPosted: November 15th, 2006, 11:24
Thanks, I agree the drive is bad. It was just strange to see all green blocks and have it happen on the two x335s I was looking at. Didn't know if that was a problem with MHDD or not. But since another x335 had more normal results it probably adds weight to the drive dying.
