 Post subject: Maxtor firmware repairer
PostPosted: February 3rd, 2007, 8:30
Hi. Im using SalvationData's maxtor firmware repairer to fix my hd but I need a working boot.cod file for a DiamondMaxPlus 8 40GB 63040L0711005 K,M,G,A. Anyone have it?
Ive looked alot of places but I only seem to see ldr & rams files and they only work for pc3000 right? Id be very appreciative of any help you can give.
Thanks.
 Post subject:
PostPosted: February 5th, 2007, 14:45
I have a few Firmware modules for Diamond Max Plus 8 40GB.
What is the Firmware version?
Im not sure if the boot code is the same on all Firmware revisions.
 Post subject:
PostPosted: February 6th, 2007, 2:18
Thanks for the reply, I think its NAR61EA0.
 Post subject:
PostPosted: February 6th, 2007, 3:39
Try this one, I think it should work for you.
http://rapidshare.com/files/15146545/BOOT.COD.html
Do you just need the Boot.COD, or do you also need the MOD's?
 Post subject:
PostPosted: February 6th, 2007, 4:59
I have Maxtor DiamondMaxPlus 8 40GB NAR61HAO too, I use MHDD to set password, but now I not forget password. Are you have a program that can remove password?? Or I must be run program to fix firmware? I want to download SalvationData's maxtor firmware repairer Pro but I haven't got money. Where can I download it? or who are you share it to me?? My English is not good, sorry! Thanks!
 Post subject:
PostPosted: February 6th, 2007, 5:34
Ive just been following the manual and it said I needed the boot.cod file. I dont know what the mod's do...
Ill try this and see how it goes.
 Post subject:
PostPosted: February 6th, 2007, 6:41
Hmm well I used that file and I no longer get a hdd error when booting and the drive is recognised in post but I cant see it in windows. The only thing that didnt go perfect when using the firmware repairer was after uploading the boot.cod file, in hdd_info it said it was K C G A whereas my hd is K M G A. Every other code/serial number matched up. :? :?:
 Post subject:
PostPosted: February 6th, 2007, 9:53
Ok, this should change it to KMGA.
http://rapidshare.com/files/15187555/BOOT.RAM.html
 Post subject:
PostPosted: February 6th, 2007, 12:28
Thanks HEAPS for all these files. Id given up getting them.
But unfortunetly that last file didnt change anything. I loaded the .cod file, then .ram using [RW EMS]. Didnt change any firmware
 Post subject:
PostPosted: February 6th, 2007, 16:28
well,...
The Boot.COD is only for Startup of the Hard drive.
Please give detailed description of the problem.
 Post subject:
PostPosted: February 10th, 2007, 8:12
I cant see the drive in windows and it still says N40P in bios. I think would like to have the exact firmware (KMGA).
I'd go the pc3000 route but its impossible when I cant read the russian interface.
 Post subject:
PostPosted: February 10th, 2007, 9:07
Run scan mode, and please post the results.
 Post subject:
PostPosted: February 10th, 2007, 9:32
The manuel says a self scan will destroy the data, so I dont wanna try that yet.
Also does it matter that the firmware code isnt EXACTLY the same?
 Post subject:
PostPosted: February 10th, 2007, 10:13
Noooooo, :shock:
don't run selfscan! (unless you don't need the data) selfscan will wipe your drive. Run [SCAN Mode]. You should have this function on the GUI.
 Post subject:
PostPosted: February 10th, 2007, 10:38
I cant see that button :? . Im using v1.20
 Post subject:
PostPosted: February 10th, 2007, 12:09
You should be using Maxtor Firmware Repair Pro 6E/6Y.
 Post subject:
PostPosted: February 10th, 2007, 12:35
Yeh, 6E0x.exe
 Post subject:
PostPosted: February 13th, 2007, 8:12
Heres the pic from the manual that im going by. Cant see [scan_mode].
 Post subject:
PostPosted: February 14th, 2007, 14:36
I was going to try running [Fix mod] but im a little worried. In the manual it says to fix the HD if you DONT care about the data to use [fix mod]. But then later on in other procedures that DO keep your data it tells you to use [fix mod].
So can anyone clarify if using [fix mod] wipes the data?
Also while im here what about when emptying the G-list or moving it to P-list?
Just incase I try that.
 Post subject:
PostPosted: February 14th, 2007, 14:43
If you want the data do not touch the G-list
Users browsing this forum: Google [Bot] and 78 guests
