 Post subject: Slightly off topic, but what the hey!
PostPosted: April 2nd, 2007, 5:59
Anyone got any good tricks for SD cards?
From a digital camera.
Windows won't see card, in fact when you insert it into card reader, the PC won't do anything.
DE will not see it.
DOS based apps (i.e. Media Tools Pro), will not even boot with this card inserted.
Do we think this card is toast, or possible to recover pics?
Many thanks in advance
Sean
 Post subject:
PostPosted: April 2nd, 2007, 9:42
The reader may be damaged as well. Did you try another reading device?
Regards,
weaker
 Post subject: SD
PostPosted: April 2nd, 2007, 11:41
Hi my friend!
already I had a problem seemed, tries to clean the metallic contacts
Good lock
Нет ничего невозможного
 Post subject:
PostPosted: April 2nd, 2007, 11:42
I unsolder the flash from it, then read the contents (I use a reader I built myself) and restore the logic structure by software afterwards.
I am currently working on how to restore the card itself after such damage.
So this is not an easy issue.
U can try Xeltek's SP3000U programmer, but I had difficulties using it, and now it is damaged, so I built my own.
regards,
 Post subject:
PostPosted: April 2nd, 2007, 15:14
Yeah, I tried another reader. Both readers work with another SD card, but not this one :-(
And cleaned the contacts.
No Joy :-(
 Post subject:
PostPosted: April 2nd, 2007, 15:31
Looks like the card is password protected. When a password protected SD card is explored the windows status is set to busy and it do nothing.
You can unlock this via Treo 600 or Unlocker systems that come with latest mobile unlocking boxes.
may be I am wrong :oops:
 Post subject:
PostPosted: April 2nd, 2007, 18:03
Hmm, can these cards get accidently passworded?
Maybe I'll give it a go, my friend has all the latest mobile phone unlockig stuff.
Cheers
 Post subject:
PostPosted: April 2nd, 2007, 18:09
regards,
Sounds very complicated!
I was kind of looking for an easier solution.
I don't mind doing a bit of soldering, but building a flash reader seems a bit overkill to retrieve one card.
But Pepe, many many thanks for your input. Intelligent and helpfull as always, respect!
 Post subject:
PostPosted: April 2nd, 2007, 19:26
Thx,
Sorry I cannot suggest anything easier.
Except one :) this has just came to my mind.
U may try to solder the flash IC onto a similar card, if the problem was in the controller IC, this should solve it.
I had a case when the card had a bath in the sea, then tried several times in several readers and cameras, obviously with no success, then I did this process and recovered the full data easily using a card reader.
Yes, these processes require many overhead and doesn't worth it for one card.
But we are hoping many cards will get bad, aren't we? :lol:
regards,
 Post subject:
PostPosted: April 3rd, 2007, 1:53
Can this process also be used for recovering bad usb's ?
 Post subject:
PostPosted: April 3rd, 2007, 2:34
yes, but that's a bit more complicated since there can be more than one memories and the data is scattered between them because of speed considerations.
and besides it is scattered within one memory as well, since there are blocks writeable in paralel.
that causes some trouble we have to cope with :)
regards,
 Post subject:
PostPosted: April 8th, 2007, 2:16
What software do you use to change the structure? Wouldn't that be real tricky, depending on how many flash chips there were, and how each control chip decided to arrange the data?
regards,
 Post subject:
PostPosted: April 10th, 2007, 5:29
Sorry for posting kinda off topic but I need help with my Memory Stick Pro Duo, which I low level formated (with some errrors) and now it isn't even discovered by my PSP or my PC :(
What can I do?
Thx in advance
adark
 Post subject:
PostPosted: April 10th, 2007, 15:22
to rchadwick
I use what I write :)
First I have to analyze the structure, then write some code to put everything in place.
to adark:
buy a new one? :)
 Post subject:
PostPosted: April 10th, 2007, 15:59
They are real cheap no need wasting time on it .
Users browsing this forum: ccc and 59 guests
