 Post subject: bad partion table how to recover?
PostPosted: April 20th, 2007, 0:16
salam alekm
i have ibm hdd with bad pt when i use dataextractor with crating virtual translator all what i can see is first drive and and other drives is not exist please help what to do in steps?
 Post subject:
PostPosted: April 20th, 2007, 3:15
if ibm hdd is just having bad partition table no need to create virtual translator for bad partition table u can use testdisk to correct partition structure .
 Post subject: what is testdisk and how to use?
PostPosted: April 20th, 2007, 7:54
salam alekm
 Post subject:
PostPosted: April 20th, 2007, 8:30
Search with Google and you'll find out.
 Post subject:
PostPosted: April 20th, 2007, 15:47
Why are you using Data Extractor? Do you know what Virtual translator in DE means?
Forget about DE. It's too complicated for you. Scan the drive with R-Studio and it will find all the partitions.
 Post subject:
PostPosted: April 22nd, 2007, 7:26
If the disk is too unstable to connect to PC, you can mount it in DE and run R-Studio (assuming you have the latest version of PCI DE)
 Post subject:
PostPosted: April 23rd, 2007, 14:49
if the drive is unstable it is the best to make an image ASAP.
then try any logical recovery on the clone.
Users browsing this forum: Google [Bot] and 300 guests
