 Post subject: maxtor 6y120l0 firmware problem
PostPosted: April 21st, 2007, 1:18
salam alekm
i have maxtor 6y120l0 the pcb had bad ic power we changed it it works but the serial dosent appear and firmware end with letter z in maxtor utility and i cant start utility i loaded ldr file it makes the firmware good and z letter gone but still no serial and when try to start utilty it gives me error message " maxtor technican error ........" when try to restart hdd using internal sa program 1 or 2 it fails i changed the rom with new one but from 6y80l0 pcb it still the same when i load ldr the z is gone and when reset hdd z is back so what to do ?
 Post subject:
PostPosted: April 21st, 2007, 3:02
Does it enter the utility after u have changed the ROM chip using LDR ?
 Post subject: no its still the same
PostPosted: April 21st, 2007, 12:34
salam alekm
no its still the same cant entre the utility
 Post subject:
PostPosted: April 21st, 2007, 12:55
Why did you put on ROM from 6Y080L0?
Why not the ROM from the original board?
 Post subject: i thought the problem in original rom so i switch it
PostPosted: April 21st, 2007, 13:31
salam alekm
i thought the problem in original rom so i switch it with other one but still the same and does the ldr loaded in sa or in ram
 Post subject:
PostPosted: April 22nd, 2007, 4:45
There is never problem in the ROM . Rom is changed when change pcb so it matches the firmware code of the hdd . The utility does not enter this hdd bcz
there may be a fw problem or errors in uba .[/b]
 Post subject:
PostPosted: April 22nd, 2007, 4:46
There is never problem in the ROM . Rom is changed when change pcb so it matches the firmware code of the hdd . The hdd does not enter the utlity bcz
 Post subject: and how to repair these errors in uba?
PostPosted: April 22nd, 2007, 9:13
salam alekm
 Post subject: Re: maxtor 6y120l0 firmware problem
PostPosted: April 23rd, 2007, 12:03
You should update your PC3000 PCI to a newer version. :P
 Post subject: u mean version v2.27?
PostPosted: April 23rd, 2007, 13:55
salam alekm
 Post subject:
PostPosted: April 24th, 2007, 14:54
yes.
Users browsing this forum: Google [Bot] and 130 guests
