 Post subject: Motor failures for diamondmax 9
PostPosted: April 28th, 2007, 9:33
Hi a question for all experts. Got a batch of diamondmax 9 drives to play with last week and 5 out of 20 have this same problem. All voltages are ok and output to motor has good voltages. All phases of motor have good readings. 1 drive had spindle stuck but was freed by opening drive and turning platters at hub. The other 4 were free to spin ( I checked through the access hole on the side). Was wondering if this is a common problem with these drives or am I missing something?
Points to add I don't care about data. This is a hobby and just trying to learn more. :wink:
I think ST is a sub company of Lucas
 Post subject:
PostPosted: April 28th, 2007, 14:54
maybe the motor's windings are brogen/burnt. check their resistances against a working one!
 Post subject:
PostPosted: April 29th, 2007, 15:46
yes pepe is right pls check it resistances..
 Post subject:
PostPosted: April 29th, 2007, 22:51
Thanks guys guess I wasn't clear enough.... All phases of motor have good resistance readings (1.9 ohms). 12v at all 3 phases when measured to ground. 0v potential between mot A mot B & mot C so all 3 phases are getting same voltage. Fuse good and 3.3 & 5v good. No servo & no motor spin. Spindle not stuck. Has to be motor as good PCB will not spin also. (checked tonight). So must be motor....... :? [/quote]
 Post subject:
PostPosted: April 30th, 2007, 8:10
Does the disk sing a tune? I have many of these myself
 Post subject:
PostPosted: April 30th, 2007, 8:19
No that's the weird thing, I have had drives that do sing, they usually have bad controllers or are missing voltage to the motor so you are hearing the heads but no spin. These are completely dead but have power at all the right places. BTW I opened one up and found it had been dropped. It is possible for the servo magnet to become displaced on Diamondmax9 even with the cover on. If jarred hard enough the magnet can jump off the locating pegs and they don't use mounting screws!
 Post subject:
PostPosted: April 30th, 2007, 9:13
Shortscurcuits you could disable connections from PCB to the preamp, and leave only motor connected. If drive spin up then most probably preamp is dead , if won't spin again, then for sure the motor is bad. But test it with known good pcb.
DataRecovery.bg
 Post subject:
PostPosted: April 30th, 2007, 22:05
Thanks Guys I'll try and get back to you I want to check some more as I must be missing something, probably obvious! :roll:
Users browsing this forum: Google [Bot] and 319 guests
