 Post subject: Problem with PHILIPS HDD070 MP3
PostPosted: April 30th, 2007, 7:08
My PHILIPS HDD070 doesn't work and I can't reinstall the firmware, because every time I try I must format the device and this doesn't work properly, maybe because track0 is damaged. What can I do? Please help :>
 Post subject:
PostPosted: April 30th, 2007, 7:57
Replace the Hard Drive. You need to buy one of the 1.8" PCMCIA Toshiba Hard Drives. Depending the size you need this may not be cheap (the larger capacities are bulkier and may not fit in your device).
Removing the hard disk is quite easy but if it is under any warranty then you would be better off getting a repalcement
Users browsing this forum: juliansagebiel and 110 guests
