 Post subject: IBM 20 GB Model # IC35L020AVER07-0
PostPosted: May 23rd, 2007, 13:05
i had lost my two partitions and i used test disk and the getdata back FAT but it not properly recognizing my Hdd and give error in while scan for data i used (PC3000 ISA ) on it because the drive was making noise when i was recovering my drives but after using the (Pc3000) it is not giving error on scan for data
any suggestion
 Post subject:
PostPosted: May 23rd, 2007, 14:18
U didn't provide any info about what U made to the drive with PC3k.
It probably had some bad sectors beforehands, but now... :roll:
If it is not giving those errors, I suppose U scanned the drive and remapped the bads, in this case it is possible U are facing the problem of shifting caused by the remap to PSHT.
regards,
 Post subject: RE: Post subject: IBM 20 GB Model # IC35L020AVER07-0
PostPosted: May 23rd, 2007, 14:28
I did SMRT clear and yes i did scaning too
 Post subject: RE: IBM 20 GB Model # IC35L020AVER07-0
PostPosted: May 24th, 2007, 4:36
I think i did wrong some thing in doing so coz i was in hurry now any suggestion what to do so i can recover my data from it>?
 Post subject:
PostPosted: May 25th, 2007, 3:20
is ur drive name and capacity showing correctly in bios ?
PostPosted: May 25th, 2007, 5:02
Yes the capicity is showing correct but when i am using the test disk to recover the partition so its says error in partition and also it start make a lil noice inside (I is that can be the LDR or Module Problem? )
because when i tried to make the LDR file so it says (Unreadably the HLDR1 and HLDR2 and another i forget;
 Post subject:
PostPosted: May 27th, 2007, 4:39
There are modules currupt in this drive chk fw structure and rewrite bad modules could u tell me the error as it is that it shows in Testdisk .
PostPosted: May 27th, 2007, 14:05
can u tell me where i can get the firmwares to download coz i dont have any correct firmware that model thanks
 Post subject:
PostPosted: June 1st, 2007, 3:11
This is a pretty common hdd u can copy from some ok hdd .
Users browsing this forum: No registered users and 106 guests
