 Post subject: HDD BEEPS! No Spin Up. HELP! WD Caviar 2500
PostPosted: May 27th, 2007, 8:00
I have a WD Caviar WD2500.
I bought it a while ago to put in to an external enclosure.
Recently I tried to plug it in to use, and the Drive would not boot up.
It just beeps! Two electronic sounding beeps very close together and then about 2 seconds later it repeats over and over.
The drive makes no other sounds or functions. the platers are NOT spinnng up.
I tred it out in 3 other working enclosures and still no improvement.
I can not afford a recovery service. right now and the data is valuable.
Does anyone know what these sounds mean? is it possible that I could take the control board off the bottom of the drive and swap it out with another? ,even the same model?
or is this an indication of a more serious issue inside? PLEASE HELP!
any info I can get would be much apricated. thanx.
 Post subject:
PostPosted: May 27th, 2007, 10:00
Sounds like either the spindle motor has seized, or the heads have become stuck to the platter.
 Post subject:
PostPosted: May 28th, 2007, 10:26
I agree with pcimage.
Reference http://www.iswamp.com/data-recovery/har ... ery-10.php for relieving stiction.
Rick
The Data Recovery Resource Center
 Post subject:
PostPosted: May 28th, 2007, 14:09
I recommend using this method only when U have nothing to lose if the HDD becomes irrevertably unrecoverable by means of some heads being torn off by the moment of the starting spindle.
If U cannot afford losing the entire data, the best is to look for a DR center.
regards,
 Post subject:
PostPosted: May 28th, 2007, 15:53
Yep, send to DR centre if u need data.
Users browsing this forum: No registered users and 46 guests
