 Post subject: MaXLine Plus II Preamp Replacement
PostPosted: August 5th, 2007, 19:40
I have a MaXLine Plus II 250 GB YAR41BW0 drive that PI believe has a bad preamp. I fried a donors board. My question is, will I be able to replace the preamp or will I have to replace the entire head stack.
Thanks, for your help,
Ben
 Post subject: Re: MaXLine Plus II Preamp Replacement
PostPosted: August 6th, 2007, 19:49
:shock: anyone?
PostPosted: August 6th, 2007, 20:16
I don't know what YOU would have to do, but personally I would NOT try to replace the preamp because of the difficulties of handling the stack & soldering under a microscope, not ruining the flexible circuit traces, etc.
Good luck.
http://www.datasaversllc.com
PostPosted: August 7th, 2007, 3:16
It is not that difficult to replace that preamp thing, but U need clean room, good soldering equipment, more skill and experience, experience, experience...
regards,
PostPosted: August 7th, 2007, 15:02
Thanks Pepe. what I'm wondering is if it is possible to replace the preamp with this family of drives. maxtor 7y250p0?
PostPosted: August 7th, 2007, 15:34
only need clean then you can take your time and desolder and resolder :D .But a Cool Ide is To Replace the Same .Would Like To Know What i Would Do [ If i would have a cleanroom ]
PostPosted: August 7th, 2007, 18:37
ok, I went ahead and did a head stack replacement. Unfortunately it didn't work. I had an identical donor and I thought it went without a hitch but when I power the drive on it clicks lightly once, waits a couple seconds, and then clicks loudly and continuously. Can anyone tell me what this means?
Any help will really be appreciated.
PostPosted: August 8th, 2007, 10:19
Put head stack back into donor and if the donor clicks then you've damaged the heads. If it works OK then the heads are incompatible.
Users browsing this forum: Google [Bot] and 90 guests
