 Post subject: " Format terminated " What problem can it be?
PostPosted: August 30th, 2007, 23:22
I'm using win 98 boot disk to check my 40GB Maxtor HDD. I able to do fdisk, deleted the old
partition and created a new primary partition.
I did a restart and try to format the HDD. But after 1%, it stop the formatting. Showing
" HDD not ready" & " Format terminated"
Can someone pls tell me what are the possible problem?
Jas
 Post subject: Re: " Format terminated " What problem can it be?
PostPosted: August 31st, 2007, 3:24
Weak/bad sector / Try check with MHDD
My Forum
PostPosted: September 1st, 2007, 15:33
Format terminated occurs when there is a series of bad sectors in one row .
PostPosted: September 5th, 2007, 14:57
Banned User
format terminated occurs when there is bad sector in this area,
PostPosted: September 8th, 2007, 23:51
Especially with "Drive not ready" or to that effect, sounds like the HDD is giving the dreaded click of death. :evil:
PostPosted: September 18th, 2007, 4:09
Thk you for all the advice. Just one more question.
Will there be any solution to help save the HDD?
PostPosted: September 18th, 2007, 4:29
Using MHDD, erase the entire hard drive from sector LBA 0 until end. If this process fails, there is no way to save the HDD.
My Forum
Users browsing this forum: Google [Bot], melvin and 63 guests
