 Post subject: Hi! Donor required for heads. Help?
PostPosted: October 1st, 2007, 6:11
Hi all,
Donor WD drive required.
This is an Apple oem drive, so struggling to find.
Model is WD1600JS-40MVB1
DCM: DSBACTJAA
I am "reliably" informed by Salvation Tech support that it's necessary to match the first 4 digits of the DCM number.
Cheers in advance
Sean
 Post subject: Re: Hi! Donor required for heads. Help?
PostPosted: October 2nd, 2007, 9:28
PCImage,
Weird. I was under the impression that you only need to match 5 and 6 of the DCM. Sounds its different for Apple OEM drives.
A
PostPosted: October 2nd, 2007, 10:12
ac,
yeah, thats what i thought.
But David in Salvation Technical says it's first 4 for these Marvel drives.
I'll check with him again
Cheers
Sean
Users browsing this forum: Google [Bot], nicola and 289 guests
