 Post subject: WD600BB module 20 corrupted any chance to get the data?
PostPosted: November 27th, 2007, 22:32
Hi Guys
WD600BB with module 20 (pdlist) error, crucial and unique to this drive, any chance to get the data?
And the following modules are also corrupted 43, 2B and 02.
thank you
 Post subject: Re: WD600BB module 20 corrupted any chance to get the data?
PostPosted: November 28th, 2007, 4:40
Is the RZtbl OK? (module 25 or 78 I think, from memory)
If so, then u can try a smart hot-swap
PostPosted: November 28th, 2007, 11:38
So, the problem is that you can't regenerate translator because P-List(43) is also bad, right?
In this case try to read both copies of 43 ignoring reading errors and combine them into one. Usually only first 15 sectors or so contain valuable data and all the rest - just 00.
PostPosted: November 28th, 2007, 20:06
Sean, Starling & Beto thank's all feedback, it turned out to be H0 and H2 very weak, beto suggested DE head map so i am trying now.
PostPosted: November 28th, 2007, 20:58
Hi
there is also a log of the factory scan - I don't remember the mod number, maybe 12h - U may try to recalc translator using that.
PostPosted: November 28th, 2007, 21:34
thank's pepe
Users browsing this forum: Google [Bot] and 317 guests
