 Post subject: SAMSUNG SP1654N after Zero-Fill HDD won't work
PostPosted: March 7th, 2008, 9:29
Hey
I filled my hdd with zeros, it hanged... i restarted my pc
and my hdd is now dead :(
No known utility won't work... it shows my drive in bios and utilites,
mark & s/n are all ok, but i can't make any patritions and if i scan for errors
then all sectors are BAD :(
IS my drive realy dead or something can make it useble again?
Thax
 Post subject: Re: SAMSUNG SP1654N after Zero-Fill HDD won't work
PostPosted: March 7th, 2008, 11:15
A real silly question, forgive me if it's too obvious. Was this your boot drive?
If not, can you try again filling with zeros?
PostPosted: March 7th, 2008, 11:47
it can't fill with zeros anymore... only what this drive does
is low level format with samsung utility... and in the end it gives a
error... if i run seatools or any utility for check errors, then all sectors are BAD...
Like the heads are damaged... or i don't no what anymore :(
PostPosted: March 7th, 2008, 12:16
Drive Fitness Test say's:
Device is Password prodected and can not tested.
I have test almoust every utility on UBCD 4.11.
PostPosted: March 7th, 2008, 15:58
Hi What Utility did You Use .
initially
PostPosted: March 10th, 2008, 3:18
Hi
I used Active KillDisk Free Edition v4.1 on the ubcd.
It hanged and after that i can't do anything with my disk.
No known utility won't work :(
PostPosted: March 10th, 2008, 3:43
Try Active Killdisk again Cos it Might Be Password Protecting the HDD Before Doing Zerofilling ,
PostPosted: March 10th, 2008, 3:47
Hi try HDD password removal tool in dos to remove password.
Thanks.
PostPosted: March 10th, 2008, 4:27
Sadiq ,
What If He Does Not Remember it ?
PostPosted: March 10th, 2008, 4:58
i have'nt put any passwords... and atapwd can't put or erase any passwords and gives a error :(
active killdisk won't see my drive.
PostPosted: March 10th, 2008, 9:18
i just used samsung sutil's and it say's DRQ timeout, when i wanted to to Entire_erase???
PostPosted: March 10th, 2008, 11:51
mhdd says it is password prodected, but can not remove :(
but i found a programm called a-ff repair station, it say's it is
prodected with password and it can be removed with this programm, but it costs :(
PostPosted: March 11th, 2008, 0:52
Hi try this program in dos ATAPWD 1.2
Hard Disk Password Utility you can remove the password.i hope it gets resolved.
PostPosted: March 11th, 2008, 3:27
HI
Atapwd says Command rejected by drive????
Has someone used a-ff repair station... does it work???
PostPosted: March 11th, 2008, 7:33
Hi, i don't know about Aff-repair i have tried ATApwd it got resolved.
Thanks.
PostPosted: March 12th, 2008, 6:21
Anybody??? pleazzz.
PostPosted: March 13th, 2008, 10:06
A cheaper alternative to A-FF Repair Station would be HDD Unlock Wizard: http://hddunlock.com
Dmitry
PostPosted: March 14th, 2008, 5:02
Has someone used it?
What means DRQ timeout? is'nt it a real hardware error?
Thax
Users browsing this forum: No registered users and 174 guests
