 Post subject: Donor needed: WD5000KS-00MNB0, HCACAJAAA
PostPosted: January 14th, 2008, 11:55
I'm need donor drives for my broken WD drive:
MDL: WD5000KS-00MNB0
DCM: HCACAJAAA
WWN: 50014EE055579D8A
PCB Part#: 2060-701383-001 REV A
Any help would be appreciated.
Artur
 Post subject: Re: Donor needed: WD5000KS-00MNB0, HCACAJAAA
PostPosted: January 14th, 2008, 16:34
Does anyone know how to figure out firmware version from stickers on hardrive?
I cannot find it anywhare and since drive is now dead this might be only option.
PostPosted: March 28th, 2008, 7:02
did you manage to fix this problem?
I have the same problem and need help with data recovery
PostPosted: March 28th, 2008, 13:27
No, I was not able to find donor and after talking to some people and reading on this forum I concluded it was not PCB problem. I did not want to atempt to do anything with heads and I do not have tools to fix firmware. Also, data was not that important to me so I gave up and send it WD for warranty replacement.
Good luck!
PostPosted: April 2nd, 2008, 12:34
Hello
We have used parts and pcb boards for hard drives mail for parts
If we have i will try to help with parts
Hard drives from 10Mb to 2Tb MFM/RLL/SCSI/IDE/SATA/PATA/SAS
DRIVES / PCB / BOARDS
