 Post subject: ATA-Password on a Seagate 2.5" IDE? Any way to remove it?
PostPosted: April 2nd, 2008, 6:02
Hi All,
I have a Seagate ST96812A 2.5" IDE hard disk with a ata-password set on the disk. The password is unknown and needs to be removed.
This disk was actually removed from a Maxtor External USB hard disk, the owner was not aware of any password on it. I have tried all the passwords they guessed, none of them were correct.
I have a PC-3000 UDMA and cannot find a way to remove the password for this model as it does not appear to be supported by the PC-3000 UDMA for 'security erase'.
I have also tried Repair Station (http://www.hdd-tools.com) but this cannot remove the password from this model disk either.
Can anybody suggest any way using ANY tool which can remove the password from this disk?
Thanks a lot for any help.
 Post subject: Re: ATA-Password on a Seagate 2.5" IDE? Any way to remove it?
PostPosted: April 10th, 2008, 9:26
You can try Shinobi from YEC: http://www.yec-usa.com/products/shinobi.htm
It comes with Atola Unlocker module made by us; it supports 2.5" Seagate and even Hitachi hard drives.
Dmitry
PostPosted: April 13th, 2008, 9:37
Do you know if it supports a Seagate ST96812A? Do you know how much this costs?
PostPosted: April 21st, 2008, 12:29
*bump* Any answer to this last question?
PostPosted: April 21st, 2008, 16:33
Have you tried a firmware update? Perhaps yours is one that will lose its password when updated.
http://files.hddguru.com/download/Firmware%20updates/Seagate/
PostPosted: April 21st, 2008, 16:45
This guy has helped a lot of people solve password issues, mostly BIOS passwords for Dell laptops. There is a huge history of questions and answers in several threads at http://www.techspot.com/vb/index.php. He apparently partnered-up and has his own answers site at http://www.download.centre4service.com/home.html
Anyway, he posted someone else's story about a laptop hard drive, where the password was controlled in the PC BIOS:
http://www.download.centre4service.com/harddrive.html
...Curious, even if not exactly applicable.
PostPosted: October 12th, 2008, 18:37
1. Dowload the "HDDErase" application from "http://cmrr.ucsd.edu/people/Hughes/SecureErase.shtml"
2. Burn the image to CD which comes with app.
3. Boot your computer with the CD and follow the instructions.
It unlocked my Seagate ATA drive, but I don't if it will help you. :wink:
And, thank to this guy; Dr. Gordon F. Hughes
PostPosted: October 13th, 2008, 2:38
I have the impression, that some of the answers here oversee, that
the question was "unlock" the drive - which is different to the usual
advice "erase + unlock"
I times of very, very cheap drives, I assume its always about "restore
or get access to data" instead of just refurbishing an onld 20 or 40GB
drive....
In all the published informations of available soft- or hardware I find
this point always unclear.
I.e. HDD-Erase will once started lock the drive and not unlock it until
the erasure process is finished.
Is there a tool on the market which definitely unlocks the drive without
erasing the data?
PostPosted: October 13th, 2008, 3:01
Yes, not free tools but there are. PC3000 for example, or you need to access the SA And work with security subsystem. Sometimes this feature need additional HW.
PostPosted: October 13th, 2008, 6:51
Salvation Seagate Doctor is the solution.
http://salvationdata.com/data-recovery- ... iew.htm#a1
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: October 13th, 2008, 7:25
to access Seagate SA (HW is must)
__________
THANK YOU
SHAHI
PostPosted: July 7th, 2010, 12:14
You can access the SA by terminal, you do not need to buy the HW. :)
PostPosted: July 9th, 2010, 15:18
terminal is the hardware .
PostPosted: July 9th, 2010, 17:02
Yes is HARDWARE SPECIAL!! :mrgreen:
Нет ничего невозможного
Users browsing this forum: Google [Bot] and 271 guests
