 Post subject: Western Digital Drive Required MOdel WD5000KS-00MNB0 - URGE
PostPosted: March 28th, 2008, 6:50
Western Digital Drive required in working condition.
Need as a donor drive for data recovery.
Must be -
Model: WD5000KS-00MNB0
Date: 05 May 2006
Will pay top price for working unit.
Thank You
 Post subject: Re: Western Digital Drive Required MOdel WD5000KS-00MNB0 - URGE
PostPosted: April 14th, 2008, 12:56
I have three of these, purchased together, still under warranty. I am trying to recover data on one of them that has developed physical problems, but a replacement is on the way, so that will make three again perhaps. The other two were removed from a working RAID set as part of an upgrade. It's all the same to me if I buy new or reuse these.
What are you thinking of for price? I would expect it to be above retail for my troubles.
-Brian
PostPosted: April 14th, 2008, 15:39
Brain,
Please can you check the other working drive that you have, I need to match as much of the following information as possible.
Specifics: Date: 05 May 2006
Product of Malaysia
DCM: HBACAJAA
PCB:2060-701383-001 REV A
I'm not sure about the retail price, but I'm sure we can work something out if I can use your drive to recover my data.
Thanks in advance for your help.
PostPosted: April 14th, 2008, 20:58
The model and PCB are a match. The DCM is different; I don't know what that means.
The other working drive is busy on data recovery right now, but will hopefully be spared soon. I expect a replacement for the faulty drive to arrive Wednesday, then I can post information about it at the same time.
Please understand that I need to come out of this with matching drives for a new RAID set, so I have to buy new replacements if I give these up. Two sold at $150 would make my day.
BTW the two good drives were nicely cooled in an Antec case; the failed one was in an external case without a fan. Is it always heat that does it these days?
PostPosted: April 15th, 2008, 4:22
$150 for the 2 drives is fine. Please let me have the information for the other drive. I will need to confirm with the data recovery company with regard to suitability.
Thanks again for your help.
PostPosted: April 15th, 2008, 10:17
I cannot replace these for $150. I meant $150 each, $300 total. I hope that's not a shock. I will post data when I can get at it.
PostPosted: April 15th, 2008, 10:53
I am happy to pay that...but would need an exact match of the above specification. Lets review the spec of the second drive.
thanks.
PostPosted: April 16th, 2008, 18:49
I have received the replacement for the bad drive, but it is a new WD5000AAKS, manufactured 12 April 2008. How could it get here from Thailand so fast? They must set them up and date them in CA.
So I have only two WD5000KS. Picture of the second label attached, others in my first post.
Serial: WMANU1082828
Date: 09 March 2006
Product of Malaysia
DCM: HCHCAJAH
and
Serial: WMANU1084304
Date: 09 March 2006
Product of Malaysia
DCM: HBHCAJAA
If these are satisfactory, then please advise how you would like to do this transaction. I have eBay and PayPal accounts. I could put them on eBay, or whatever you like. I am in Buffalo, NY.
PostPosted: May 17th, 2008, 14:32
One of my returns got me a recertified drive as follows:
Specifics: Date: 03 May 2008
Product of Malaysia
DCM: HCACAJAA
PCB: 2060-701383-001 REV A
That differs by only one letter in the DCM, plus the recert date, of course.
More:
WWN: 50014EE05558DFAF
It's still sealed from WD direct.
PostPosted: May 25th, 2008, 12:48
Hi.
I'm looking for a PCB as picture above. I'll be happy to purchase the entire drive. Do you still have any?
PostPosted: May 25th, 2008, 14:46
I have the sealed recertified drive just mentioned, plus another that I intend to send back to WD for a warranty replacement. I suggest you probably want the recertified drive, still sealed from the manufacturer, but it's all the same to me. I have attached images of each.
File comment: Recertified drive
PostPosted: May 29th, 2008, 19:31
...and the label of the recertified drive:
PostPosted: May 29th, 2008, 20:52
Basic postage options:
Postage to UK.pdf [70.36 KiB]
Downloaded 750 times
PostPosted: June 14th, 2008, 2:18
I am looking for a WD 5000ksrtl with DCM HBACAJAA.
Did you find one? Do you know where I can get one to change out the heads on my dead one?
Thanks for any help.
PostPosted: December 24th, 2008, 10:23
Hello All,
I need a western digital drive similar to the following
Specifics:
Date: 26 May 2008
Product of Malaysia
DCM: HCHCAJAA
WWN: 50014EE0AAAC1A17
Thanks.
PostPosted: February 20th, 2009, 13:49
Hello All,
I need a western Digital Drive similar to this DETAILS cus my hdd is toasted and i have some very needed data on it
MODEL : WD5000KS-00MNB0
Specifics:
Date: 13 MAR 2006
Product of Malaysia
DCM: HBHCAJCH
WMN:50014EEDAAAAEB5B
thanks in advance
Users browsing this forum: No registered users and 84 guests
