 Post subject: Dropped 2'1/2 Hard Drive
PostPosted: October 11th, 2005, 20:06
Dear all,
this morning, i have dropped my portable hd, and the shock has been heavy ...
when i plugged it in the usb2 port : strange noise and nothing ...
I was a bit disapointed ... i have tried some little shocks/shakes on the drive but it has not helped ...
since i have no experience in hard drive problem and haven't got any idea on how to repair it, i decided to open it, just to see !
once done, i found that the arm that holds the head was in the middle of the disk. i have pushed it slowly to place it out of the disk (plate ?). I quickly close this, plug it in the usb case ........... tada ............ it worked !!!!
i was very proud ! but E/S errors have come quickly .... no problem for the data, they are backup elsewhere. but the drive is quiet usefull for me and i do no want to buy another one.
I think that some part of the drive are deffective but some others are good. i spend a few time on the net to find advice/software, and found mhdd in UBCD (ultimate boot cd). I have had a quick look to the doc and to the faq and i started a scan on the drive. a few seconds later the screen was displaying red cross and other 'bad' symbols in the map ...
i cancelled the scan (it was very long) and typed erase.
a few seconds later, the soft hangs and explain me that the device is broken (catastrophic failure/error ...). I restarted mhdd with the switch to not use bios and retyped 'erase'.
the erase is running for more than 2 hours now, and it has performed about 10% of the work (oups). But i will be patient, and i will let him go to the end.
After that, i plan to do a scan + erase and a scan + remap.
What is your feeling about this little story ?
Will the drive be usable as in the past, but with a lot of bad sectors Or do you think i am loosing my time and i can throw the hard drive to the bin ?
Thanks for your avices !
 Post subject:
PostPosted: October 11th, 2005, 21:35
Good work as far as the recovery is concerned!
But I wouldn't spend a minute on the repairing this drive.
Once you opened it be happy with your data and do not expect to much of the drive.
(IMHO)
see ya,
 Post subject: Right Pepe
PostPosted: October 12th, 2005, 3:07
Right Pepe .............
 Post subject: Re: Right Pepe
PostPosted: October 16th, 2005, 5:37
And also the fact that you scraped the head across the platter probably caused your new media errors... Use it now as an ashtray or some new modern art thingy
A man is as old as he feels, and a woman as old as she looks
Users browsing this forum: Google [Bot] and 387 guests
