 Post subject: WD GENERIC BAD SA?
PostPosted: June 23rd, 2008, 9:47
Hi to all!
PCB is good!
Look logs in label hdd!
Problem?
WD400EB GENERIC ID save.txt [2.37 KiB]
Downloaded 1019 times
WD400EB GENERIC ID normal.txt [2.33 KiB]
Downloaded 964 times
Нет ничего невозможного
 Post subject: Re: WD GENERIC BAD SA?
PostPosted: June 23rd, 2008, 9:48
sempre wrote:
Hi to all!
PCB is good!
Problem?
LABEL look
PostPosted: June 23rd, 2008, 16:19
U check modules in PC3000?
PostPosted: June 23rd, 2008, 16:54
Hi disable head 1, no click... look logs
bad head 0..
WD400EB 1 head disable.log [1.01 KiB]
Downloaded 968 times
WD400EB GENERIC IDdis 1 head.txt [2.33 KiB]
Downloaded 982 times
PostPosted: June 24th, 2008, 10:26
Hi to all!
attempt to read given of the H1
Please Look log...
:vo:
some help?
:mrgreen:
WD400EB hto swap.log [7.36 KiB]
Downloaded 985 times
