 Post subject: Maxtor Onetouch III RAID
PostPosted: July 14th, 2008, 3:53
I have a Maxtor onetouch III, no partition is found, the drive is RAID but not sure Raid 0 + 1 or else. Does anyone know how to get the data ? I am using Rstudio but dont know hot to configure the RAID settings. Thanks.
 Post subject: Re: Maxtor Onetouch III RAID
PostPosted: July 14th, 2008, 4:23
Your better off using Winhex. Use trial and error to find correct block size.
PostPosted: July 14th, 2008, 10:09
Hy terranova, hr u?
wich File system use this RAID ?,
Best regards friend
Sincerlay
Alberto
PostPosted: July 14th, 2008, 10:16
hi Beto, great...thanks.... the filesystem is NTFS.
PostPosted: July 14th, 2008, 10:35
RStudio can determine the strip size, offset, etc. with just a few clicks. It's pretty much menu driven - If it returns a no confidence state, then increase the number of samples (i.e. read more of the drive).
http://www.datasaversllc.com
PostPosted: July 14th, 2008, 10:38
How many drives do you have in the RAID set?
This will help determine what for a RAID set you have. If you have only 2 Drives, then it can only be RAID 0 or RAID 1. If you have 3 or more drives then it most likely is RAID 5, but It also could be RAID 0.
If you have RAID 1 (mirrored disks)
then all data will be mirrored on the second drive, therefore one drive should be mountable and have all the data, therefore no DR is needed.
If you have RAID 0 (striped disks)
then you need to image the drives as virtual drives in R-Studio (Virtual strip set) or any other software for that.
PostPosted: July 14th, 2008, 21:49
thank you guys for all your help, i will try.
Users browsing this forum: No registered users and 202 guests
