 Post subject: Need Seagate Barracuda ST3320620AS for PCB sawp
PostPosted: July 16th, 2008, 15:39
I am looking for a Seagate Barracuda 7200. 10 320Gbytes for swapping PCB with defect HDD.
model: ST3320620AS
P/N: 9BJ14G - 305
Firmware: 3.AAE
PCB number: 100406528 C 7714RAL8
Images are of the HDD with defect PCB
 Post subject: Re: Need Seagate Barracuda ST3320620AS for PCB sawp
PostPosted: July 17th, 2008, 7:15
Hi
What's the number on the "Agere" chip?
I have a PCB which may be suitable, but you'll have to swap the ROM. (Which you'll probably have to do anyway)
PostPosted: July 17th, 2008, 15:44
I also have the same PCB .
PostPosted: August 11th, 2008, 18:30
Hi
I'm also in need of the exact same PCB, it's a friends drive and he broke the plug connector and a couple of pins.
Drive details:
ST3320620AS
P/N: 9BJ14G-305
Firmware: 3.AAE
Date Code: 07122
Site Code: WU
What do you mean by needing to swap the ROM as well? What's involved in that?
Many thanks
Lucas
PostPosted: August 11th, 2008, 19:46
if its just the connector, power or data, thats broken swap ONLY those bits from the donor PCB to yours. Don't swap the whole PCB.
PostPosted: August 11th, 2008, 19:53
unfortunately some of the pins have broken off the PCB, not sure how to replace just those without lots of fine soldering :)
Users browsing this forum: Google [Bot] and 63 guests
