 Post subject: Maxtor Fireball 3 detects as VAM52JBZ
PostPosted: July 23rd, 2008, 5:42
Dears,
I have a problem with Maxtor Fireball 3 20GB drive.
PC3000 detects is as VAM52JBZ and shows as 0 capacity [MB()].
I see on the drive label VAM51JJ0 so something is wrong.
Do you have any suggestions how to get data out from it?
Regards,
Rafal
 Post subject: Re: Maxtor Fireball 3 detects as VAM52JBZ
PostPosted: July 23rd, 2008, 6:29
hi did you try to enter with a loader and create its own loader?
Data Recovery pro in Italy
www.ultrarecovery.com
PostPosted: July 23rd, 2008, 6:34
I suppose the problem with loader but I can not find any for my drive (20GB). Hddguru contains only for 30GB and 40GB. Do you know where can I find ldr for my drive?
Regards,
Rafal
PostPosted: July 23rd, 2008, 7:02
30 gig loader will do, it is some module error...
HddSurgery - Professional Data Recovery Tools
PostPosted: July 23rd, 2008, 8:00
If you want, give me (pm) your e-mail and i'll send you one for 2F020J0-VAM51JJ0
PostPosted: July 23rd, 2008, 9:36
Looks like a SA problem, if u got DRDY DSC ATA registers but when u tried to read x sector u got ABRT, its an syntomph of SA problems wich should be checked SA Modules
Alberto
PostPosted: July 23rd, 2008, 10:45
I am coming back with the problem. Thanks to IRS I received ldr but it doesn't work. It stops during loading overlies. So I tried use other loaders and few work showing correct firmware but capacity is 40GB.
So when I try to pass through utility start there is an information that
- read roadmap - ok
- read roadmap extension - ok
- read zone allocation - ok
but it stops futher with error: UBA 8 reading error. Drive is not ready.
Do you have any suggestions?
Regards,
Rafal
PostPosted: July 23rd, 2008, 11:13
What version PC3000 u using?
PostPosted: July 23rd, 2008, 11:30
this is 2.20.
Regards,
Rafal
PostPosted: July 23rd, 2008, 20:33
raf-pl wrote:
Dears,
Regards,
Rafal
Multiple letter is changed, this can be head damage!
Did you try to replace?
The NAR61590 fw shows up NAR6253Z with dead head!
The same letter is changed.
Regards,
Janos
PostPosted: July 24th, 2008, 12:08
Fireball 3 is complex and worst HDD ever manufactured by Maxtor. Anyway, it might SA defect...
Individual experience can identify the truth.
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: July 25th, 2008, 15:06
Most of the time when this drive shows 0mb it mostly head problem.
PostPosted: July 26th, 2008, 4:06
yea, for most of the case.
but most of the case for Fireball 3 Series in my experience its SA defect.
__________
THANK YOU
SHAHI
Users browsing this forum: No registered users and 282 guests
