 Post subject: Seagate PCB Swap
PostPosted: May 15th, 2008, 18:49
Hi guys,
I have a seagate ST3160812A that someone plugged the wrong power supply into ( it was in an enclosure and the enclosure was plugged into the wrong power supply ).
It will not spin. I believe there is a short in the PCB because when I install the drive in a desktop, the desktop will not start ( I believe it detected a short )
I'm going to try the PCB swap.
Found a drive with same:
firmware
site code
model
same RPM
I see others on here who mention config having to be the same and HDA P/N.
Where are those?
What do you guys think my chances are?
 Post subject: Re: Seagate PCB Swap
PostPosted: May 15th, 2008, 23:39
Hello : alcon_s
Found a drive with same: model; FW version; config; number of PCB or same the electronic parts : IC controller; IC motor and swap the ROM
thanks
PostPosted: May 16th, 2008, 21:17
sigitharjono,
Thanks for responding.
Where is the config? Isn't that a number on one of the chips?
Not sure how to match the IC controller.
Can you help me?
PostPosted: July 24th, 2008, 23:14
HI alcon_s:
have you solved you problem?i got the same suitation with you. I have a st3160815as HDD damaged pcb.i tried swap the pcb with the same modle,firmware ,date code,site code, all chip on the pcb are the same with the broken one and almost printed mark on the pcb are the same ,but it does work ,only the motor spin but the bios does found the HDD. can you give me advise?or if you have any issue please email me! ok? my mail is chen158333@139.com.thanks very much!
PostPosted: July 25th, 2008, 15:12
post terminal log here for more help .
PostPosted: August 5th, 2008, 4:04
hi everyone here is the msg from com cable:
4096k x 16 DRAM
NHAWK - 1_Disk S-42 03-27-07_13:01
Buzz
can somebody examine the problem for me? thanks!
PostPosted: August 6th, 2008, 15:20
motor problem .
PostPosted: August 6th, 2008, 22:30
thanks for you reply! but it spin normally,and i can heard the sound of the head movement.
PostPosted: August 7th, 2008, 14:38
4096k x 16 DRAM
Buzz
This msg means that the motor is initialized or stuck after initialization after that head parks/unparks and drive reach ready state , In short if your pcb was working fine on the other hdd and on your drive gives this msg then most probably its a preamp problem .
PostPosted: August 8th, 2008, 0:35
i think, mostly the unit of head was not good! anyway thanks for you reply!
another same modle ok seagate gives below msg:
Reset
4096k x 16 DRAM
Buzz HM SFI
(P)SATA Reset
(H)SATA Reset
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 330 guests
