 Post subject: Problem HD WD200
PostPosted: August 9th, 2008, 15:43
Hello I have an HD WD200 that stopped what could be the problem sorted the photos if someone can give a hint already thank
Luiz
 Post subject: Re: Problem HD WD200
PostPosted: August 9th, 2008, 15:50
Seem everything allright from the photos.... symptoms ?
PostPosted: August 9th, 2008, 15:59
Is the motor spinning or do u hear clicking sounds ?
PostPosted: August 9th, 2008, 16:26
No clicking, no sound, total stop.........
Luiz
PostPosted: August 9th, 2008, 17:03
When he connects the power supply will not turn on engine, not click, completely stopped
Luiz
PostPosted: August 9th, 2008, 17:20
I have one drive, and do this too exactly.
The pcb is cold, the program not runs on the mcu.
(in my case)
I have tested the pcb with donnor, and the problem is around the flash.
Maybe helps.....
Janos
PostPosted: August 9th, 2008, 17:34
Thank you'll see more Janos also not found in Q1 voltage as shown in photo
Luiz
PostPosted: August 10th, 2008, 11:28
Try to change your PCB with donor PCB.
PostPosted: August 10th, 2008, 12:24
This is the problem because the HD is not found yet another former PCB compatible, so I wonder if any component may be the defective thank any help
Luiz
PostPosted: August 11th, 2008, 10:34
Hy
Tried to find any PCB of course similar card to adjust on the screws , using the same spindle controller, that would be enough to check , if hdd spin“s,
PostPosted: August 11th, 2008, 12:25
I did the test the engine is running normally, I did the test with another PCB of a different model
Luiz
PostPosted: August 11th, 2008, 13:15
Luiz, did you check what I suggested in PM ? Check with scope on the original PCB, if completely dead something is stopping supply.... otherwise search around the logic (MCU/Flash/Ram).
Yet, another PCB same model could help as reference !!!
PostPosted: August 11th, 2008, 18:29
PCBs, or put a WD300 to know if the engine was turning, the engine turned normally, not clearer, but it difficult to find a compatible PCBs I will check the components again
Luiz
PostPosted: August 20th, 2009, 2:09
I have this pcb in Brazil, where are you from?
-BR-
Users browsing this forum: No registered users and 85 guests
