 Post subject: WD5000KS failure mode?
PostPosted: August 11th, 2008, 22:20
I have seen a couple of WD4000KS & WD5000KS drives. (The 5000KS has 8 heads and 4 platters).
The typical symptom is three clicks or so and then shutdown / recycle.
I did a hot swap and was able to image data from heads 0,1,2,& 4. But nothing from 3,5,6 & 7.
Is this type of failure one of misalignment? Dirty heads? Bad heads?
http://www.datasaversllc.com
 Post subject: Re: WD5000KS failure mode?
PostPosted: August 12th, 2008, 1:38
Poor overall quality and misuse. How old were them and where bought? PM ME.
PostPosted: August 12th, 2008, 4:01
What criteria did you match for a donor for hotswap?
PostPosted: August 12th, 2008, 8:24
I matched model and DCM. Drives were manufactured about a week apart. I think this is close enough to try a heads swap, but I don't think I will attempt it.
Jon
PostPosted: May 14th, 2009, 18:04
I have a couple of these drives in right now; with two different failures:
Failure type 1: As Jono described, ~3 clicks and then repeat. For me these clicks are slow clicks in one or so second intervals.
Failure type 2: Drive struggles to power on; on my current monitor the 12v is spiking to ~1200 then 0, 1200 then 0 over and over every once in a while it will actually spinup. It doesn't seem to be a PCB issue; I am guess the internal circuit on the motor.
Anyone have insight on these drives? I am mostly interested in Failure type 2 I talked about here, as type on is more then likely heads I would think. (fun time there.)
PostPosted: May 25th, 2010, 13:20
I have a WD4000KS that clicks about once a second a few times and then shuts down. What do you mean by "hot swap" when you said that hot swapping the wd5000 fixed it? Thx
Kyle
PostPosted: May 25th, 2010, 13:39
Something that is not possible without specialized equipment
PostPosted: May 25th, 2010, 13:54
Have 2 in the shop waiting for the donors. But cant find em =(( The only one i found was 320$.
PostPosted: May 26th, 2010, 5:11
And what will you do when u find donor?
PostPosted: May 26th, 2010, 8:44
If you find donor, I would buy a minimum of 2 donors.
PostPosted: May 26th, 2010, 8:45
I agree
PostPosted: May 26th, 2010, 10:08
swap the heads.
@ HddSpaz and Hddguy Ty =) ill keep that in mind.
PS Before u tell me - i am aware of pain in the butt Zeus drives seem to conjure.
PostPosted: May 26th, 2010, 10:59
Ok,
we can solve it in case u need some services.
PostPosted: May 26th, 2010, 11:04
pepe wrote:
Ok,
ty Pepe.
PostPosted: May 30th, 2010, 15:50
jono-ats wrote:
...WD5000KS drives...
I have a similar scenario - were you able to find a cause/solution? Were you able to recover any data?
If so, can anyone recommend a DR service near Atlanta that won't charge me an arm & a leg?
Many Thanks!
PostPosted: May 30th, 2010, 17:32
jono-ats from this forum .
Users browsing this forum: No registered users and 161 guests
