 Post subject: view factory defect list
PostPosted: November 3rd, 2004, 12:48
The following functions are present:
The fastest exact diagnostics of a mechanical part of the HDD
Bad sectors repair
Monitoring of IDE registers
Opportunity to physically reduce size of the HDD (HPA function)
Automatic Acoustic Management — adjusting noise emanation level
SMART. Error logs. Running SMART tests and view attributes
Full HDD erasing
Work with security system of the HDD. Installation, removal of the password
Warm-up the HDD and test the HDD in extreme conditions
View factory defect lists
Packet testing of a set of drives.
And others possibilities...
Dmitry or Bastard:
if mhdd software can execute all of the above mention, I would like to find out how to "view factory defect list" for a hard drive. Please advise.
thanks :beer:
 Post subject:
PostPosted: November 3rd, 2004, 13:26
i removed that crap. if you want, you can use mhdd 2.9 to view fujitsu and ibm lists...
Yes!
 Post subject:
PostPosted: November 3rd, 2004, 21:15
It's a nice feature .... don't know why you removed it. I was trying to read a defect list from a hitachi laptop drive since pc3k doesn't support it and I thought your software would.
thanks for the quick reply. :cool:
 Post subject:
PostPosted: November 3rd, 2004, 21:44
Could you explain me, for what? What to do with this feature?
 Post subject: MHDD add feautures
PostPosted: November 4th, 2004, 16:28
Exactly, what is the use of VIEW defect list if you cannot update/erase. Ok maybe for
buying new HDD's but you can always check the SMART of the drive.
Or maybe ok for digging factory cmmands? :bebebe: I guess no harm in IBM G list and Quaxtor Defect lists because there not so confidential to people
Posted 4/11/2004, 22:33:
To be honest I don't really use MHDD but I thought it would be cool (Classe ;o) ) if you could add a feauture to make batch commands VIA task file ports?
say like IBM Format Unit command
Unlock IBM with TXT file of your own found master passwords , auto unlock if file found. Or even better!!! Add feature to extract ICES crypt/decrypt file from good drive :beer: but I guess that won't happen... Also Toshiba password decrypt would be nice.. will send you :thankyou:
 Post subject:
PostPosted: November 5th, 2004, 13:32
Dmitry... I need the defect list for shiftpoints. If I can view that with mhdd, I won't need to scan for it.
:beer:
Users browsing this forum: pepe and 323 guests
