Post new topic Reply to topic  [ 27 posts ]  Go to page 1, 2  Next
 Post subject: HD Duplicator
PostPosted: July 17th, 2007, 22:51
I purchased HD Duplicator a few months ago. At first, the author was very helpful, but now he no longer responds to my emails, and the name, password, and link I was given no longer works. I lost my downloaded copy and need to download another, and was hoping for the latest version or the latest beta. Does anyone know what happened to Copyr? Are they still in business?
 Post subject: Re: HD Duplicator
PostPosted: July 30th, 2007, 0:58
Hello Robert
Sorry for long time answer. I was in buisness trip.
I still place your HD Duplicator version in update box. Beta version will be available in your personal folder soon.
GL
PostPosted: July 30th, 2007, 1:04
I got it. Thanks again.
PostPosted: August 1st, 2007, 10:45
We've been trying to contact you as well to get access to the newest beta. We purchased HDD Duplicator earlier this spring "Chipheads Computer Repair". Thanks!
PostPosted: August 4th, 2007, 0:18
irrision
Sorry for delay. Beta version is placed in your update box.
PostPosted: October 8th, 2007, 23:02
New version of HD Duplicator is available. Official user's can take it in their update boxes.
PostPosted: February 13th, 2008, 7:55
Hello Copyr,
when do you plan to release new version of HD Duplicator with fixed bugs? Current version is C239.
-In some situations Hddup hangs immediately after start if in DMA mode (both disks are ATA).It doesn't clone any sector, just hangs and i need to reset. If switched into PIO it works fine.
-cannot clone SATA disks, have to use SATA-ATA converter
-HDDup sometimes restart the drive through the power controller, but only waits about 2 seconds and restart again and again in the loop. Even if there is a limit 60s (or any other) in the setup "expectation of readines after power on"
-limit of number of config files
-log file is not correctly written when cloning interrupted
There are also some features we would like to see in new version
-Could you add an option to write the file.512 also to skipped sectors? Currently it is only written into unreadable sectors. It is a "must have" as sometimes i only need to fast copy readable sectors and i don't want to proceed in more steps. And if the skipped sectors are not replaced with file.512 i cannot find later which files are damaged.
-when cloning the drive without the check of control sum it always try to read 2 times regardles of the setup and it is very slow.
PostPosted: September 14th, 2008, 12:28
HD Duplicator new version relised
Short list of updates:
- Algorithms of copying faulty disks are changed. Stability of work is improved.
- New mode of copying with pre-verification.
- Saving of a defects map during copying in case of switching-off PC.
- Copying SATA and SCSI disks on Intel chipsets is corrected.
- Opportunity of switching-off of reading SMART parameters.
- The program for creation bootable Flash. For installation HD Duplicator on Flash USB Stick.
PostPosted: September 14th, 2008, 13:14
Thanks for releasing a new version! Can you put it in my box as well?
PostPosted: September 14th, 2008, 16:10
Yes, I put new versions in update boxes for all official users. Also updated website copyrsoft.com with new materials will be available at the end of the week.
PostPosted: December 1st, 2008, 12:16
hello,
Somebody could help to discharge the program hd duplicator complete version.
Or if it is commercial where I can buy it.
Greetings
Juan
PostPosted: December 1st, 2008, 13:18
It is commercial. copyrsoft.com.
PostPosted: December 1st, 2008, 13:31
Hello, rchadwick
You dressed the it paginates that you indicate me, but they delay in answering, I see that comprastes the program last year, as much as you cost.
Give me your email to converse on the matter.
Thank you
Juan
PostPosted: December 2nd, 2008, 10:09
Alexey its not answering now, maybe he its outside im trying to contact with him but he doesnt answer me from 2 month´s ago by the way rchadwick did u tried to use the new version on SAS HDD¨s? i tried but hangs with dump memory error, hangs when tried to detect the hdd´s , im using a PCI SAS Controller, i tried with different chipset motherboards and same problem , i tried with good SAS Disks, Seagate and the patient its Maxtor SAS
PostPosted: December 2nd, 2008, 16:52
I haven't tried it yet with SAS, but since this is the first version that supports SCSI (I think, not 100% sure), it might need some work still. Hopefully Alexey gets back soon.
PostPosted: December 3rd, 2008, 8:07
beto,
I'm not sure what's the problem with SAS disks, I tried find bug, but I can't. We use FastTrak TX4650 and FastTrak TX2650 SAS controllers, all works well.
Juan,
I answered to you by e-mail.
PostPosted: December 3rd, 2008, 11:21
Hello alexey nice see u again, its strange i tried with different SAS HDD´s Seagate and Maxtor, well im going to still checking with another MB chipsets, im using fast trak too,
PostPosted: December 12th, 2008, 6:52
Suggestions:
1. New map color for crc read sectors.
2. Beeping noise when finished.
3. Feature to zero erase hd.
4. Ability to select read sector size 1-256.
PostPosted: April 16th, 2009, 14:38
Hi all!
I download the HD Duplicator demo from copyrsoft homepage (size limitation 30Gbyte).
But I can clone a 40Gbyte Maxtor.
What is the size limitation of HD Duplicator demo?
Thanks in advance.
PostPosted: April 16th, 2009, 23:18
There are two ways: to buy full HD Duplicator professional product, or you
can use our freeware software COPYR.DMA
(http://www.freedownloadscenter.com/Util ... R_DMA.html)
it is HD Duplicator little brother (has no LBA48 support (disks bigger than
137 Gb) but it can help you with yours 40Gb disk copy).
Users browsing this forum: No registered users and 17 guests
