Sorry to bother you guys but this just priceless
That guy anaesarora kept bugging me with PM
here is some of his perls
He PM me about this
viewtopic.php?p=62281#p62281Here is the message
why give more time to init ?
any reasonable logic?
drive spins at high speed 5400 to 7200 depending on make and type
a minute is enough to make many bad sectors and whip a tired drive to work more ... use logic .... not whipping a drive.
do you know of any methods to give rest to a drive . by rest i mean a scientific way to make the drive better in health and performance?
i know you dont knowany basic way to make a bad drive healthy.
search the net... read more... be dedicated to this forum , dont bull. have you ever tested a drives condensor ? a diode? a controller chip, a rom , a eeprom, and do you know where to identify on a logic board. do you have a 16 x magnification loop glasses to see tracks ?
you dont?
can you tell me how to find a input data track anda utput data track on a controller chip.?
can you expain where are +and - 5 and + and -12 volts
on a logic board.?
can you tell why it is colored green ?
can you tell how many layers of a pcb of a mother board have.
why are pins of a processor made of gold?
why pinless processors are used today?
what is the material used for riveting the pcb?
how can one extend the life of a pcb to 10 years with simple techniques?
why are manufacturers now inverted the circuity on hdd pcb logic boards.
have you ever tried to identify the ic on the preamplifier in the internals of a media.
what is the resistance value of the head on a internal media circuitry?
what is the magnetic flux of the magnets used in the internals of media.
how many turns of wire and what lamination techniques are used to make a coil in the media.and what is the gauge of that laminated wire.
what is the material to conduct electricity in the flat cables in the media.
can those flat cables get charred?
which one gets charred?
have you ever examined those flat cables as one of them is smoked with wrong voltage when you use wrong connectors by mistake?and you blame the head.
have you repaired those flat cables with a conducting paste.
which companies make that conducting ribbon paste?
have you ever seen the laser holes on a hdd ? and why have they been made?
have you ever seen them , do you know how centifugal force is generated on the surface of platters which keep the head micro mm above the platters.?
this is experience and i am a doctor too lol
god bless you.
if you can answer correctly i make you my guru.
