 Post subject: Flash Disk Sony Vaio 120GB Corrupted Files !
PostPosted: November 26th, 2008, 5:19
hello I,m Low Level format by llf , hdd wipe compeleted .
formated by partion magic on fat 32 .
copy file on flash disk , stop usb flash disk ,
conect flash to usb port see corrupted file dos not to open all file and character name file
please help me i,m live in Iran :(
 Post subject: Re: Flash Disk Sony Vaio 120GB Corrupted Files !
PostPosted: November 26th, 2008, 23:38
i think you have a serious problem if this is SSD drives, try recovery software.
PostPosted: November 27th, 2008, 14:22
I think the drive is inside the external box .
Take the drive out from the external box and connect it to a pc using 2.5'' convertor .
PostPosted: November 30th, 2008, 18:28
Sony Vaio 120GB is really HDD 2.5" in USB box, it is not SSD. I think that in this case you have damaged usb controller, but at first you should check the HDD. If you want to repair this drive, it is possible to do it with special tool (for example PC3K). Of course you may check the controller of USB box, using HDD swap. You should insert in box any good 2.5" HDD (IDE or SATA, look inside box).
Users browsing this forum: No registered users and 102 guests
