 Post subject: WD1200JB-00FUA0
PostPosted: November 20th, 2008, 13:30
Hello
Have a disk with this when i connect :
It can not show-me the SA FW Version
Anyone have this error ?
Techno mode key:
HDD geometry loading.................... : Ok
Cyl Count............................... : 81004
Head Count.............................. : 4
SPT..................................... : 900
RAM:
Zone allocation table................... : Ok
ROM version............................. : 15.BE.
SA FW version........................... : ......
Link table version...................... : 05.66.
Serial ROM:
Read ROM................................ : Ok
Heads configuration..................... : From map
Heads number............................ : 6
The number of heads in use.............. : 4
Disabled heads.......................... : Yes
Head map................................ : 0,1,4,5
Service area:
Modules table loading................... : Drive is not ready
Configuration loading................... : WD Techno Key Error Drive is not ready
Translation overlay checking (Copy 0)... : Not found in modules directory
Translation overlay checking (Copy 1)... : Not found in modules directory
ZeBong
ZeBong
" Россия еще раз"
 Post subject: Re: WD1200JB-00FUA0
PostPosted: November 20th, 2008, 16:39
What about the modules?
Can you read/check them?
PostPosted: November 20th, 2008, 17:09
i think i have idea to find out which version it's.
data recovery service[/b]
PostPosted: November 20th, 2008, 18:20
i can not read them, it appear blank.
i also try to cut head by head but nothing happen.
ZeBong
" Россия еще раз"
PostPosted: November 20th, 2008, 18:21
So what do you think it is ?
ZeBong
" Россия еще раз"
PostPosted: November 21st, 2008, 3:16
Modules table NOT loaded!!! (module 41.rpm [~Dir.rpm])
At first Read (backup) all service tracks...
Mikippp
PostPosted: November 21st, 2008, 10:38
hi,
that´s the problem i can not see any module and i can not backup :(
ZeBong
" Россия еще раз"
PostPosted: November 21st, 2008, 12:17
At first Read (backup) all service tracks... (tracks not modules)
You can not read modules becouse modules table was NOT loaded!!!
Then read the manual... especially informations about module "ID=41h" and about "Utility extensions".
Mikippp
PostPosted: November 22nd, 2008, 11:51
Thanks,
i go there and i dont see any backup off tracks.
ZeBong
ZeBong
" Россия еще раз"
PostPosted: November 22nd, 2008, 16:38
Its in the test menu .
PostPosted: November 24th, 2008, 14:28
Hi try to make the backup off the tracks:
But i can not, what do you think the problem is :
Reading service tracks
Into folder............................. : <HDD Profile>\Data\Tracks
Reading heads........................... : 0,1,4,5
WD Techno Read Error C/H/S: -1/0/0
WD Techno Read Error C/H/S: -1/0/1
Cyl -1; Head 0.......................... : Break
WD Techno Read Error C/H/S: -1/1/0
WD Techno Read Error C/H/S: -1/1/1
WD Techno Read Error C/H/S: -1/1/2
WD Techno Read Error C/H/S: -1/1/3
WD Techno Read Error C/H/S: -1/1/4
Cyl -1; Head 1.......................... : Break
ZeBong
" Россия еще раз"
PostPosted: November 25th, 2008, 8:20
You use original PCB with original ROM ?
Did you try the head check?
wd1200bb-changed-rom-and-pcb-still-not-work-t7717.html
Mikippp
PostPosted: November 25th, 2008, 14:49
Mikippp
Yes,
Everything is original.
ZeBong
" Россия еще раз"
PostPosted: November 27th, 2008, 14:33
I think problem with head 1 .
PostPosted: December 22nd, 2008, 19:21
Anyone have one disk to seel need the heads match
WD1200JB-00FUA0
ZeBong
ZeBong
" Россия еще раз"
PostPosted: December 23rd, 2008, 10:59
Do you need a drive to work with a drive discussed above?
www.datarecoveryne.com
PostPosted: December 23rd, 2008, 14:13
This things happen :) today i turn on the disk and it can be detect byt the udma.
Techno mode key:
Cyl Count............................... : 15468
RAM:
SA FW version........................... : 15.BER
Serial ROM:
Service area:
Modules table loading................... : Ok (Copy 0)
Configuration loading................... : Ok
Master Password......................... : has not been set
User Password........................... : has not been set
Translation overlay checking............ : Ok
Also i start to make a copy with DE but it give ecc error,
Anyone can help on this ?
ZeBong
ZeBong
" Россия еще раз"
PostPosted: December 23rd, 2008, 14:31
You have to read it by head map and read the ones that do read and then work with the ones that don't read.
PostPosted: December 23rd, 2008, 20:03
Try to build a head maps but it give error.
ZeBong
" Россия еще раз"
PostPosted: December 23rd, 2008, 20:22
Make a head test :
it gives OK,
Heads test
Cylinder to test........................ : -25
Heads to test........................... : 0,1,2,3
Head 0.................................. : Ok
Head 1.................................. : Ok
Head 4.................................. : Ok
Head 5.................................. : Ok
SA surface verification
Initial cylinder........................ : -1
Final cylinder.......................... : -20
Head.................................... : 0,1
Cyl -1 Head 0........................... : Errors : 0
Cyl -1 Head 1........................... : Errors : 0
Cyl -2 Head 0........................... : Errors : 0
Cyl -2 Head 1........................... : Errors : 0
Cyl -3 Head 0........................... : Errors : 0
Cyl -3 Head 1........................... : Errors : 0
Cyl -4 Head 0........................... : Errors : 0
Cyl -4 Head 1........................... : Errors : 0
Cyl -5 Head 0........................... : Errors : 0
Cyl -5 Head 1........................... : Errors : 0
Cyl -6 Head 0........................... : Errors : 0
Cyl -6 Head 1........................... : Errors : 0
Cyl -7 Head 0........................... : Errors : 0
Cyl -7 Head 1........................... : Errors : 0
Cyl -8 Head 0........................... : Errors : 2
Sectors :Error
304.....................................
319.....................................
Cyl -8 Head 1........................... : Errors : 0
Cyl -9 Head 0........................... : Errors : 0
Cyl -9 Head 1........................... : Errors : 0
Cyl -10 Head 0.......................... : Errors : 0
Cyl -10 Head 1.......................... : Errors : 0
Cyl -11 Head 0.......................... : Errors : 0
Cyl -11 Head 1.......................... : Errors : 0
Cyl -12 Head 0.......................... : Errors : 0
Cyl -12 Head 1.......................... : Errors : 0
Cyl -13 Head 0.......................... : Errors : 0
Cyl -13 Head 1.......................... : Errors : 0
Cyl -14 Head 0.......................... : Errors : 0
Cyl -14 Head 1.......................... : Errors : 0
Cyl -15 Head 0.......................... : Errors : 0
Cyl -15 Head 1.......................... : Errors : 0
Cyl -16 Head 0.......................... : Errors : 0
Cyl -16 Head 1.......................... : Errors : 0
Cyl -17 Head 0.......................... : Errors : 0
Cyl -17 Head 1.......................... : Errors : 0
Cyl -18 Head 0.......................... : Errors : 0
Cyl -18 Head 1.......................... : Errors : 0
Cyl -19 Head 0.......................... : Errors : 0
Cyl -19 Head 1.......................... : Errors : 0
Cyl -20 Head 0.......................... : Errors : 16
Sectors :Error
1.......................................
11......................................
15 -- 16................................
20 -- 21................................
25 -- 26................................
30 -- 31................................
35 -- 36................................
40 -- 41................................
45 -- 46................................
Cyl -20 Head 1.......................... : Errors : 24
Sectors :Error
10 -- 11................................
17......................................Drive is not ready
22......................................Drive is not ready
27......................................Drive is not ready
32......................................Drive is not ready
37......................................Drive is not ready
42......................................Drive is not ready
47......................................Drive is not ready
SA surface verification completed
ZeBong
" Россия еще раз"
Users browsing this forum: No registered users and 42 guests
