 Post subject: recover data from toshiba hd
PostPosted: January 14th, 2009, 7:07
I want to recover data from a Toshiba mk1637gsx hdd2d60 c zk01 s 160 gb I have been told to get a new electronics board for the drive. Any body have one or advice on how to proceed. the drive came from an iomega 160gb portable usb/firewire unit 1 year old
many thanks
john
 Post subject: Re: recover data from toshiba hd
PostPosted: January 14th, 2009, 7:13
try describing what the actual fault is. spinning? clicking? squeeeeeeling? who told you to get a new board and why? I'll tell you something for nothing, new board wont work without modifications. You need the help of a pro, it's gonna cost you.
PostPosted: January 14th, 2009, 7:31
hi
thanks
the drive does nothing. Local computer guys checked it out. Iomega data recover guy said if i get a drive with same model and firmware then i could swap electronics board (with help?) which he said was more than likely dead. the board in the iomega also is dead
john
PostPosted: January 14th, 2009, 7:33
The data recovery guy knows Jack. Send it to a 'REAL' Pro.
PostPosted: January 14th, 2009, 7:35
Toshibas have unique adaptive data on PCB and PCB replacement will not work.
PostPosted: January 14th, 2009, 7:36
Can you suggest someone
PostPosted: January 14th, 2009, 7:38
where are you based?
PostPosted: January 14th, 2009, 7:43
is there anything that can be done and that wont cost a fortune
(a story heard many times i suppose)
iam based in ireland
PostPosted: January 14th, 2009, 7:46
depends what you mean by fortune. www.google.co.uk search data recovery. shop around.
PostPosted: January 14th, 2009, 8:08
If your PCB has failed, it will probably need replacement including transfer of adaptive data, which is located on a BGA chip on this model - which requires specialised equipment. Simple PCB swap will NOT work.
It's not going to be cheap, but PM me if you like, I'm in IRL.
Data Recovery Ireland
PostPosted: January 14th, 2009, 8:18
CK. Easy Recovery your baby? World's longest half price data recovery sale. 5 years and counting. :lol:
PostPosted: January 14th, 2009, 8:23
You have not really described any symptoms with your toshiba, PCB replacement may not even be nessecary.
PostPosted: January 14th, 2009, 8:29
Come on Spaz, please don't insult me. Half price recovery that triples in price when it has to go to the UK?
No, I run the only real DR company here, with proper ESD and Class 100 equipment. We don't sell ink cartidges/fix PC's/train people to type or paint walls. Too many cowboys masquerading as DR but acting as agents for UK companies, like most other markets I suppose.
PostPosted: January 14th, 2009, 8:33
sorry to insult you. my mistake. should have realised that. I've heard and experienced only good things from them :? I'm sure easy recovery are based in belfast any how.
PostPosted: January 14th, 2009, 8:34
also I believe they outsource to ontrack. well they used to. they have also tried to outsource to a few others too. 8)
PostPosted: January 14th, 2009, 8:39
What amateur doesn't??
We've seen plenty of their work from unhappy customers where prices have spiraled out of control. Anyway, I'm not going to start attacking individuals here, we are busy enough with real work and happy customers.
Users browsing this forum: No registered users and 55 guests
