 Post subject: WD1200VE-xxKWT0 required
PostPosted: August 5th, 2008, 10:05
With DCM to suit HOTJHBB.
Thailand
Cheers
 Post subject: Re: WD1200VE-xxKWT0 required
PostPosted: August 5th, 2008, 10:39
I have had trouble finding this drive. I have posted a question about the VE and whether it can be replaced with BEVS or other product designator. Any thoughts? I am currently seeking a PCB for mine. Good luck! Let me know where you find one.
PostPosted: August 5th, 2008, 10:59
BEVS is different, but UE would probably work.
PCB I could possibly help you with.
What the p/n of the PCB (2060 xxxx xxx)?
Sean
PostPosted: August 5th, 2008, 13:54
I posted a 2061-701402-100 AB. You responded with 2060-701402-001 REV A. That wont work will it?
Have you had any success with DR on the Scorpio?
PostPosted: January 22nd, 2009, 3:48
I'm seeing these WD1200VE-XXKWT0 all the time with detached heads. Its easy to find broken ones but almost impossible to find one that works.
PostPosted: January 22nd, 2009, 15:27
Yep, virtually every WD1200VE I've had in has had detached heads. Very little success in recovery, even with perfect donor. :-(
