 Post subject: SEAGATE 120GB PATA
PostPosted: December 18th, 2008, 16:31
Anyone can help me on this:
Afther change heads i have this:
Interface task reset
1024k x 16 buffer detected
ALPINE - 1_Disk M-21 11-25-03 18:53
Buzz - Head Mask FFFF - Switch to full int.
Spin Ready
8.01 03-08-04 09:57
(P)PATA Reset
AutoRd Err 47 at 00f6ba.00.0004
CE Log EC=0 Rtype=36 OV=0 STStatus0
AutoRd Err 47 at 00f6ba.00.008b
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
Failed sys sect. write
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
AutoRd Err 47 at 00f6ba.00.0002
AutoRd Err 43 at 00f6ba.00.0002
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
AutoRd Err 43 at 00f6ba.00.009f
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
Master
AutoRd Err 43 at 00f6ba.00.000b
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
AutoRd Err 43 at 00f6ba.00.0004
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
AT Er 00 Nwt Er 00 RdWr 7ffc.00.0001
ATA St d1 Er 10 Op f9 e, df94baf,01 01 00
Niwot: 002c0000 44 00000000.2c.000 0000 0004 0001 0002
ZeBong
ZeBong
" Россия еще раз"
 Post subject: Re: SEAGATE 120GB PATA
PostPosted: December 19th, 2008, 13:42
Did a head test friend, maybe on the process something happend to know if reach Servo Mark , too
PostPosted: December 28th, 2008, 17:43
With this error i can start copy sectores green, but very very slow.
Copy in DE ( back )
At the moment i could copy about 32 xxx xxx sectors green.
Edit the sectors and start from the 90 xxx xxx copy from back to the 58 138 036
Afther here start some green and some yellows sectors but two slow
When i jump to other sectors e can copy sometimes green sometimes yellow
Can anyone give-me a suggestion.
ZeBong
ZeBong
" Россия еще раз"
PostPosted: December 31st, 2008, 4:24
Looks like this hard drive is having head problem.
Did you try clearing SMART ?
My Forum
PostPosted: January 4th, 2009, 18:19
Now, i have this in terminal :
Head Mask FFFF - Head Mask FFFF - Switch to full int.
Spin Ready
Error Reading Reserve Track Defect List
F>
I am thinking in change heads again, but i am affraid that will happen the same.
ZeBong
" Россия еще раз"
PostPosted: January 5th, 2009, 1:00
Did you try building head map when using DE ?
My Forum
PostPosted: January 5th, 2009, 2:57
What about depopping head definitively? Or different imaging strategy.
PostPosted: January 5th, 2009, 4:05
It's the main head that having problem. Impossible to disable this one.
CMIIW
My Forum
PostPosted: January 6th, 2009, 13:24
It's CE Log problem,in which the drive can be detected but it's too slow to copy data. CE Log Remove can fix such problem.
PostPosted: January 30th, 2009, 18:52
Hi again, afther change heads for the second time have this in terminal again,
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
$NIWOT TIME OUTSwitch to full int.
              AM Reacquired
AT Er 00 Nwt Er 37 RdWr 201c.00.0001
ATA St d0 Er 40 Op 20 e,  322451d,01 01 03
Niwot:  002c0000  44  00000000.2c.000 0000 008b  0a01 005f
              AM Reacquired
AutoRd Err 43 at 00f6ba.00.0079
$Switch to full int.
              AM Reacquired
NIWOT TIME OUT
              AM Reacquired
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
              AM Reacquired
$NIWOT Switch to full int.
              AM Reacquired
              AM Reacquired
TIME OUT
AT Er 00 Nwt Er 43 RdWr 412f.00.0000
ATA St d0 Er 00 Op 20 e,  3224515,01 00 03
Niwot:  03224515  4a  00004515.322.000 0000 8000  0a07 033e
AutoRd Err 47 at 00412f.00.00c5
CE Log EC=43  Rtype=5 OV=0 STStatus0
              AM Reacquired
Switch to full int.
              AM Reacquired
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
              AM Reacquired
AT Er 00 Nwt Er 43 RdWr 13a3.00.0001
ATA St d0 Er 40 Op 20 e,  3224515,01 00 03
              AM Reacquired
TIME OUT
I notice this
CE Log EC=37 Rtype=5 OV=0 STStatus0
What can i do here with the UDMA ?
ZeBong
ZeBong
" Россия еще раз"
PostPosted: February 2nd, 2009, 3:47
Use DE with the utility's option and specify a loader.
That should work.
dobre
Murphy was an optimist
PostPosted: February 5th, 2009, 14:55
Hi to all again,
Now i have this in the same disk
              Spin Ready
F>
What can i do here, change heads again?
ZeBong
ZeBong
" Россия еще раз"
PostPosted: February 5th, 2009, 15:06
zebong wrote:
Hi to all again,
              Spin Ready
F>
ZeBong
I think, this is another manuf. head.
Try to replace with the compatible one.
If you can read slowly, you have different heads, or a little platter excentricity problem....
We hope the first one. :)
Janos
PostPosted: February 6th, 2009, 7:18
Hi NC,
When i just the heads the first time and the second time yes it can ready very very slow.
I just match the SITE CODE.
I have other heads to change it again houpe this time i can copy the rest off the disk .
ZeBong
ZeBong
" Россия еще раз"
