 Post subject: Need resources for ST9120822AS 3.CAE
PostPosted: January 27th, 2009, 0:38
Need a Cert for this model
www.datarecoveryne.com
 Post subject: Re: Need resources for ST9120822AS 3.CAE
PostPosted: January 27th, 2009, 11:50
Ctrl+A ?
DataRecovery.bg
PostPosted: January 27th, 2009, 13:44
Samo wrote:
Ctrl+A ?
I don't need "smart advises" :evil: , I need a copy of the cert or a full loader for this model. 8)
PostPosted: January 27th, 2009, 16:39
I'm not giving smart advices, :oops: I ask for additional info to check my DB.
Because 3.CAE did not give information nor about version of the Cert, neither about eng rev,mask rom, orig code ....
DataRecovery.bg
PostPosted: January 27th, 2009, 18:21
3.CAE is a Firmware version
I don't know the Cert version.
I will try again and will provide details if possible.
For now I will accept any for this model with this frimware version.
PostPosted: February 6th, 2009, 12:26
I am also looking for one of these.
My drive from my macbook died, and I am looking for one to try to replace the heads or the circuit board.
So far have found none.
PostPosted: February 6th, 2009, 15:50
Describe your problem in details like; spins up, ddoes not, spins up and clicks.....
PostPosted: February 6th, 2009, 16:06
It's probably ~50 different CERT codes for 3.CAE but you don't need smart advice, so...
Here you go
File comment: CERT+Tables
3CAE.rar [216.46 KiB]
Downloaded 506 times
PostPosted: February 6th, 2009, 16:28
I have found one that I needed.
Thanks, any way. :D
PostPosted: September 28th, 2009, 14:38
I am having the same problem I need to replace my board on the following hard drive
Segate Momentus 5400.3 120 GB
SN 5RM05RNK
Model: ST9120822as
PN: 9s1133-042
FW: 2.CAE
Date 07473
Site: WU
Anyone know where to get it?
Thanks,
Daniel
Users browsing this forum: Majestic-12 [Bot] and 292 guests
