 Post subject: heads WD800JD
PostPosted: March 4th, 2009, 16:24
Hi to all!
Please infos. (kernel, marvell, sabre58) heap map changing
Hd wd800jd possesss two heads (head0,1), can incapacitate one of them pra to be certain if only one and bad or the two, later I come back to qualify the two heads (head0,1)
Techno mode key:
Tech on................................. : Ok
ROM:
ROM reading............................. : Ok
Heads configuration..................... : by map
Heads number............................ : 2
Heads number in use..................... : 2
Switched off heads...................... : No
Head map................................ : 0,1
later I change heads… comes back to work with head0 and head1?
Thanks advanced...
Нет ничего невозможного
 Post subject: Re: heads WD800JD
PostPosted: March 5th, 2009, 12:57
When you write ROM, the message is that writing completed ok?
PostPosted: March 5th, 2009, 13:29
Sorry 8)
not I have experience with wd, therefore I made this question before any action… if it will be able to help me… :mrgreen:
PostPosted: March 6th, 2009, 5:14
So, first of all, explain what happens when you connect the drive.
PostPosted: March 6th, 2009, 7:13
Ok! :mrgreen:
Clicking three times and (off) disconnect ..
:idea:
Thanks...
PostPosted: March 6th, 2009, 10:24
So, for what you've said, it has 2 heads.
Try to disconnect one at each time and check what happens.
Users browsing this forum: No registered users and 92 guests
