 Post subject: Error on HD, can't clone w/ EasyMigrate
PostPosted: March 6th, 2009, 8:39
I just purchased Acronis EasyMigrate and found an error on my HD. No lost data, just an error that I can't clean up. After a chkdsc, it says clean...but still shows error message from O&O defrag and Easymigrate.
It's a Samsung 80g Sata. The error's are c:$MFT
Thanks for any help.
 Post subject: Re: Error on HD, can't clone w/ EasyMigrate
PostPosted: March 21st, 2009, 21:11
Did some checking on the Web seems this program is bad news. Are you wanting to clone your drive so that you can install a larger drive into your computer. There is a lot better software out there on the market than this one. Here is what people say about the software you are using. Found on the Web
Ugh. Acronis's software sucks really bad. Reinstalling the OS and manually migrating the files is less painful (trust me, I have used Acronis in the past).
me too i used Acronis before and had bad memories about it.. my whole files poof...
There are a lot more out there but this should give you a clue to find something better to you. Plus there is a site only for this software maybe you should join that forum and get the answers you are looking for.
Iorana Haraharaini
PostPosted: March 21st, 2009, 22:04
Thanks,,,I've used Acronis numerous times the past with no problem "but never had an error on the HD".
I have just gotten Norton Ghost from a friend,,,but now, not working either.
PostPosted: March 22nd, 2009, 0:40
Spotmau PowerSuite 2009
All-in-One Suite: Emergency Rescue + Disk Maintenance + PC Tune-up + Privacy Protection
Emergency Rescue: Lifesaver when Windows crashes or hard drive fails!
• Boot up ANY computer;
• Rescue crashed Windows and data;
• Recover deleted, formatted, or crashed data;
• Repair Windows errors and missing file problems;
Hard Disk Maintenance: Technician's dream toolset; Easy for a PC beginner!
• Clone and backup system and data;
• Partition and format hard drive;
PC Tune-up: Return you a smooth computer as "fresh" as the first time!
• Optimize and boost Windows performance;
• Repair registry problems and Windows errors;
• Eliminate Windows freeze and hang;
• Remove stubborn and ghost programs;
• Clean up obsolete debris and trace files;
• Speedup Windows startup time;
• Optimize internet speed;
Privacy Protection: 360° privacy protection gives you peace of mind!
• Unbreakable "Personal Safe" to store confidential data;
• Clean up activity tracks on computer;
• Hide and encrypt sensitive data over transmission;
• Shred secret data permanently;
• Find lost passwords and product keys;
Try this one sounds like your hard drive has some really bad areas inside and you should change out. If you want a clone of your drive you might get what you want from this
Iorana Haraharaini
PostPosted: March 22nd, 2009, 3:28
Thank you, I'll check it out. Powersuite
PostPosted: March 22nd, 2009, 4:40
Hi. If your drive is not failing and if you don't have access to professional cloning utilities then I would suggest you try a free programme called Unstopable Copier by Roadkill.
http://www.roadkil.net/program.php?ProgramID=29
If it is a bootable drive you might have to carry out a repar after copying the data to make it bootable again. There are various ways to do this.
Then there are other freebies by Roadkill which I have never used before but must be worth a try.
Roadkil's Raw Copy
http://www.roadkil.net/program.php?ProgramID=22
or
Roadkil's Disk Image
http://www.roadkil.net/program.php?ProgramID=12
So plenty to try for free but only use these utilities if your drive is in reasonable condition.
PostPosted: March 22nd, 2009, 4:50
errors in the Master File Table bitmap ($MFT), you need to fix this first.
My Forum
PostPosted: March 22nd, 2009, 5:21
Yes of course,,trying to do that now with the Powersuite program ??? Don't think it'll work. But a nice prog for cleanup etc. Will try the cloning shortly with Powersuite.
PostPosted: March 22nd, 2009, 5:30
If that program can not fix it, you will probably need to fix it with other program or manually editing its content.,
My Forum
PostPosted: March 22nd, 2009, 6:31
How would it be possible to edit the C:$MFT files ?
PostPosted: March 22nd, 2009, 6:56
http://www.cgsecurity.org/wiki/Advanced ... MFT_Repair
My Forum
