Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
 Post subject: Re: WD HDD 1TB logic board fried
PostPosted: May 6th, 2009, 23:15
rupal wrote:
All i can say is that from my personal experience it has worked, And for others as well.
I am sorry to tell you but you are lying or mistaken. You cannot get data by making hotswap w/o original defect lists
PostPosted: May 7th, 2009, 2:09
Just to add some pepper, you are assuming the preamp is not fried. The OP said it is a drive from media server, so it's time to dig in the pockets for decent, professional help if data is important, otherwise everything including lighting up a candle in honour to ... will be useless. @ rupal, don't be surprised if you get 'skeptical' feedback : posting HERE (HDDGURU) such...er...advice is like trying to teach dad how to f..ck or to go to a NRA convention with a "hunt hunters" t-shirt... don't expect the red stripe. Hotswap can work in restricted situations and must be prepared, it's not unscrew and go.
PostPosted: May 7th, 2009, 3:18
It's this sort of bullsh*t that makes it's way onto the net and loses people their data.
PostPosted: May 7th, 2009, 4:08
rupal wrote:
What you can do is: Get a drive that is exactly the same model, size etc. It has to have been manufactured around the same time. Plug the new (working drive) into your Pc (keep both drives out of the case upside down so the logic boards are accessible) once the drive has mounted in windows, you need to put the drive to sleep (you can set windows to put hdd's to sleep after 5min) then while the HDD is asleep, with a T8 screwdriver carefully remove the board without shorting any components & leave the Power & SATA cable plugged in. Then screw it onto the bad HDD (with faulty board removed obviously) Then browse the disk & you should be able to see\backup the data. DO AT YOUR OWN RISK obviously.
Yes, and you get 2 damaged PCB if the preamp is short. :mrgreen:
Additionally, what about the factory defects, adaptives and calibration?
You will get a corrupted content in this way!
Please don't say if you don't know what do you need to say...
Read this instead:
results-the-yourself-solutions-t11912.html?hilit=results
Janos
PostPosted: May 7th, 2009, 6:22
@Rupal - Do you work for Ontrack? :lol:
PostPosted: May 7th, 2009, 17:54
Oh, maybe we don't know something : maybe there are other ways to perform a hotswap ...
PostPosted: May 7th, 2009, 18:05
@Rupal
Now i see that you have a good teacher :D :mrgreen:
Maybe if you have time you can show to us in a video what you do.
ZeBong
" Россия еще раз"
PostPosted: May 13th, 2009, 15:26
I think he is just talking about swap the pcb .
He doesnot know about hot swap .
PostPosted: May 14th, 2009, 2:24
I'm starting to think he has taken Scott's data recovery course.
Users browsing this forum: Majestic-12 [Bot] and 108 guests
