 Post subject: need the firm ware file for WD-1600AAJS-22WAA0
PostPosted: June 8th, 2009, 17:22
hello to all
i need the firm ware file for WD-1600AAJS-22WAA0
DATE:19 APR 2008
DCM : HHNNHTJCHN
westrren digial hdd drive becus i lost the old firmware
can some one help me
thnx in advance
 Post subject: Re: need the firm ware file for WD-1600AAJS-22WAA0
PostPosted: June 13th, 2009, 13:27
lost the old firmware ?
PostPosted: June 13th, 2009, 15:09
what do you plan to do with the "new" firmware?
flash it like a mobile phone?
PostPosted: June 15th, 2009, 7:30
i will flash it to my hdd
PostPosted: June 15th, 2009, 11:14
What do you mean by firmware? The ROM on the PCB or the SA on the platters? How did you lose the old firmware? What do you plan to do with the new firmware?
I'd say that you are likely better off stopping now and sending it to a professional lab before it is too late, if it isn't already....assuming that you want to get the data off the drive. Otherwise, just buy a new hard drive.
In the off chance that you just want to play, you have a huge battle against you.
At the very least, if you want the firmware for this drive, you are going to have to specify the exact firmware version that was lost.
Recovery Force Data Recovery
cron
