 Post subject: Need Guidance For Harddrive Repair...
PostPosted: July 9th, 2009, 11:11
Hi everyone.
Recently my external USB harddrive just stopped working. It will not be detected by Windows and makes a continuous clicking noise when it is plugged in. Its a 60gb harddrive and the data on it is worth more than the hard drive itself and is very important that i get it back. The quotes i have recieved from various companies so far are 400+. Im a student so this is far too expensive for me at the moment, but i really need the data back. Can i just get the harddrive repaired? Or do i have to have the data recovered. One of the guys i spoke to said companies shouldnt offer repair to harddrives and the data should be restored. Please point me in the right direction as I have no clue what im doing :(
Thanks alot,
Lewis
 Post subject: Re: Need Guidance For Harddrive Repair...
PostPosted: July 9th, 2009, 11:28
First of all, read this:
results-the-yourself-solutions-t11912.html
And this:
diy-what-the-big-deal-t12671.html
The next step, if you decided to "try to do something alone", write down the entire model, sn, capacity and all the IDs from your hdd, without disassembling it. (not on the usb box)
Janos
PostPosted: July 9th, 2009, 12:01
You can do nothing at your level. Accept the £400 quote (that sound honest) or live without data, or (plan B) save money until you can afford a pro.
PostPosted: July 9th, 2009, 12:14
Personally I would say 400 sounds cheap...
PostPosted: July 9th, 2009, 15:20
Firstly, you have to repair the hard drive in order to recover the data. The "repair" is 90-99% of the work, especially in physical (almost certainly) cases like thus. Hitting "copy" to copyout the data or running DR software on the image of the repaired drive is an insignificant part of the process. In any case, no-one with any sense will simply repair a drive only to have the end user bugger up the copyout procedure and/or claim the data was corrupted or missing and demand their money back.
Depending on the actual drive, we offer physical recovery from £295 + VAT less a hddguru discount.
As people on here will doubtless confirm some makes/models are FAR easier to recover than others, hence recovery prices may vary.
£400 "may" sound a little high for a 60Gb drive, but it's not astronomical by any standards.
Cheers
Sean
Users browsing this forum: Google [Bot] and 224 guests
